  • Replies 14.2k
cant see it at work, but im assuming its the group that says something like there are too many skylines and wrx in adelaide.
but then the people go on about how great commos are inside it :) think there's a s load more of those in adelaide
Sigh
Split the coolant hose underneath the inlet manifold this morning. Lost 80% of my coolant, managed to get it to the mechanics in time. Pissed the last litre of coolant out while it was on the hoist. They had to remove the starter motor to get to it. 2x hoses replaced. Thank f**k its not the heater core hoses. And I'd only put new coolant in 3 months ago, genuine nissan too...
-D
before or after mullers rd Ben?
before - only noticed it when i got to work, went inside to get some stuff and came out to see a massive puddle of ethylene glycol baking in the sun - looked at the radiator, had enuff to proceed but had the bottle of distilled water just in case
-D
EDIT - And main north nissan are all out of that particular hose. Dunno if I find one in silicon from anyone in adelaide before Friday either (it'll take till friday for nissan to get the hose from Melb...)
RB24...that is all :)
I don't know how much it would cost...but 2-2.5k should do it, ill scan a article out of HPI #44, where they start building a RB24, and send it too you.
and the rest abe, i reckon 2k would cover the machining
last time i checked the tomei RB24 kit was 6k :)
Yeah no shit hey. Trying to find out about catch can setups/ oil mods for some piece of mind and just when I get some useful info someone two posts down trashes it.
All I want is a lightly tuned reliable GTR.
  • Oil mods like which catch can, relocator and oil cooler
  • Front pipes (No I'm not going to AM Performance
  • Pods or panel filters
  • clutch, ebc, injectors, cams, fuel pumps.
Too many options, too many chances of buying a brand thats not going to work well.
1) those oil mods wont solve the GTR's problems, they help you at the track and changing filter, but as far as stopping them from spinning a bearing, you really need the sump off!! you can actually do the sump mods with the engine in the car, there actually is a way to take the sump off with the engine still in place! and you want to enlarge and baffel it! the other important mod is the restrictor in the head...not that easy to do, you may be able to do it from the bottom with the sump off tho, but expect to pay $$ for this
2) umm.. okay, why? u know whats on there atm? any particular reason you have singled out this part of the exhaust?
3) pods with shroud or box... once again, for a stockish car why would you want to change them?
4)
a) you having problems with the clutch at the moment? untill it start failing why change?
b) anything with a mac valve, they are the best type of electronic presure control!! (profec b spec 1 has it)
c) perhaps were starting to move away from a lightly tuned gtr?? stock turbos? its going to depend on your current plans, remember if were talking stock ecu there is only so big you can go
d) from the fourms "The answer on duration depends on what RPM range you are targetting, be realistic.
If you intend to use 7,000 to 9,500 rpm, something around 272 to 288 degrees would be the go.
For 5,500 to 8,000 rpm, around 260 to 272 and for 4,500 to 7,500 rpm then 248 to 260 is the go.
That's a simplification, but you get the idea. As for lift, once I know the effective rpm range,
I then choose the highest lift I can for that duration. What valve springs you are using will also determine the maximum lift" just note that once you get over 10.25mm lift you need new buckets as well as springs, you may also start to get clearance issues if you go much higher lift. but once again i ask why??
e) obv if your doing injectors u'd do this
perhaps its better for you to list your goals and we can go from there, but there is ALOT you do need to consider (as your finding out) and alot of the time you do one upgrade and you look at thing having to do 3 more for it!
i can see what your thinking... get the car up to a good base to work from there, but it depends on your 'current' end goals, you might not need to do some of this, and you might want to look at other things instead
1 x Hell Yeah
about time that R was out again luke....cant wait to see you at a villis meet with the R mate
cheers guys... but MORE delays!! =\
who quits work the week before they start on my car XD
What sized tire should I run on the GTR for a 9.5" rim? I was thinking maybe a 245/35 KU36 all round
I run 245's on a 8.5 rim at the track, If i was you i'd be going 255's minimum. No need to stretch your tyres on a 9.5inch rim on a GTR.\
I'm pretty sure Sled had 255's on his 9.5's on his GTR.
Edited by DSTROY
+1 GTR's should have no stretched tryes. Flush but no stretch :)
Unless their 10inch+ I think Shane has stretched 255's on RBWARE, looks f#cking porn!
Edited by DSTROY
Guest
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
