Hmmm. I might just go with a 265/35 in the KU36. For under $500 delivered for a full set of brand new semis you cant beat that
Damn thats cheap can you send me a PM in regards to where your getting them from....i am looking for new tires too mate
thanks
  • Replies 14.2k
ROR Scandy.......if you like that shit, you must like blokes too.
Normal peeps prefer the girls in the 1st part of the vid.......each to their own weird fetishes I suppose.
lol. havent checked the vid yet. been too busy browsing the pics. :D
can someone pick up something for me from Woodville North??
has to be picked up today unfortunately and i am not in adelaide, there is a 6pack in it for ya and i will take it off you on saturday? PM me asap
I wouldnt bother.
the RB25 will munch the RB20 box in no time, do it right teh first time and go a whole 25 package.
ask Ryanrb25, find him on face book, he usually happy to help with any questions you have.
just dont expect him to do it for you :D
Thanks. Ive been told by more than 1 person you can use a 20 box on 25 providing you're gentle and don't use a twin plate clutch...
Anyway found out the answer to the tail shaft question this morning.
My attention is now on how to get it registered.
i would also keep in mind to upgrade your brakes while your doing the 25 conversion Dion
yeah, just trying to do some homework.
Will probably end up with another 20 because for the price of the 25 package I can have a 20 with a hks 2530 on it... Stock 25 vs. 20 with 17psi....
ugh. its midday. i gotta be up for work at 5:30, but instead of doing the smart thing and sleep, im reading questionable content and listening to portishead.
Shame he doesn't drive it hard enough to need them :rolleyes:
badum tish.
Engine oil: check
Oil Filter: check
Coolant: check
pwr steer fluid: check
Gbox oil: check
Hopefully thats all I'll need to swap these 20s over in the Sil. Also have got a new exh mani gasket cause I'll be using the turbs off the old 20.
Bring on the weekend! Hoping to have Craigs 20 running in my car by sunday night.
Edited by AndrewJZX100
umm 25 with 12psi boost for me did really well......stock 20 wont make as much power as you think Dion
Guest
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
