  • Replies 14.2k
I wrote this up for when i sell my s13 but since I've been asked about it a few times already without putting it up for sale heres the specs
YEAR 1989
MAKE Nissan
MODEL S13 silvia - resprayed custom green – manual
MODS
Ca18det
engine has received a full o/haul and metal head gasket
kkr 330 turbo fully rebuilt with garret gt28rs internals
supra front mount with custom piping and custom intake pipe
speed lab remap
gtr fuel pump
poly urethane engine, gearbox, and sub frame mounts
gtr rear sway bar
cusco camber and toe arms
moon face traction rods
poly urethane castor rod bushes
ram rear coilovers, gab front coilovers
lock spacers
brand new exedy clutch (seen 3 track days)
new clutch master and slave cylinder and lines
full turbo back exhaust
drift handbrake button
cusco mech 2 way lsd (also seen minimal track time since new)
skyline rear 5 bolt drive shafts
obx bucket seat
clarion head unit 45x4 and clarion 6x9 speakers
16x7-0 and 16x8 +2 ssr xr4 longchamps
Pink steering wheel (straight from japland :P)
Front lower lip
Front and rear strut braces
52mm alloy radiator with all new JJ silicone piping
EXTRA COMMENTS car is fairly straight with the body work could use a little tlc, chassis is immaculate with no rust or dents in the floor pan, it made 176rwkw with the retune and has more in it if the injectors and AFM where upgraded, basically a tough street car with plenty in it for drifting.
This car has seen track time but not much at all. 3 times since January is it and it doesn’t get driven unless its going to the track. I do start it and roll around the winery where its kept in a shed at least ones a week to keep it healthy.
nearly tempted to throw in my build for that lol
cant really afford it tho :P
in parts is prob worth 8k with the rebuild otherwise id sell cheaper but just to much put init.
been told its the best sounding ca heaps of times too, pops decent flames and proved itself on the track.
have think about it dude, could be cheaper in the long run insted of building a car from scratch and this ones got some decnt stuff onit to get you started :P
heres some pics to get you thinking. its before the paint job though.
Guest
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
