  • Replies 14.2k
farkin! bit big! you could photograph Tasmania from your balcony Troy.
its kinda like that...lol that is only part of it , another part doubles the 1300mm to 2600mm. its like waist high now from the floor..lol
took some other photos with them the other day,,,but its so amazing you cant tell how far away it is of a kite surfer. he was a few K's out at least
if your a lay person like myself, this is a good read, how a rotary engine works.
http://auto.howstuffworks.com/rotary-engine4.htm
Rotary engines rock,,, rev like hell , sound isnt as smooth but still goes like hell
get used to them you might have one someday
http://www.autoweb.com.au/cms/A_55754/titl...ewsarticle.html
+1. Alot of people don't like the sound, I'm quite fond of pp/bp and turbo rotaries. Probably still to this day, a rotary is the fastest car I've been in...
Hmmm..
Cars making big ass clunking noises over bumps like the coilovers don't want to stay under the guards. All bolted up mint and tight too. Don't know wtf going on.
do u have adjustable camber arms? thats the noisiest component of my suspension
-D
I have nothing. It's actually like the coilover is about to fall out. Took the wheel off with Wayne earlier and all the bolts are tight. Shook the coilover and right at the top of the going it makes a knocking sound. I don't know if anything is hitting anywhere. But it wasn't making the noise yesterday
sounds like the bump stop needs replacing (if it even has one - some (like my old bilsteins) dont have bump stops)
-D
Guest
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
