hrm that looks good with white. methinks they'd look nice on my r32 >:)
-D
Well I'll have a set coming next week. So you can see what they look like. But I don't think you want the sizes I'm getting.. Bit too 'illegal' for your liking.
  • Replies 14.2k
yeah i think i'd be after 18x9 at most (34 gtr rim size) or the 8.5's.... but will be nice to see regardless
-D
much hope the 31 sounds like this when finished with side pipe
no craig, you want yours to sound like this
or this on idle
btw, my side pipe will be similar design and hopefully pop flames like such too
ok i just cant not post this, i know ill make a few of you blow your load.
http://speedhunters.com/archive/2009/12/08...31-skyline.aspx
fanki's car
lowest 31 in australia. loves munching front guards too
Edited by Matty 31
/chop images of pron 31
sounds O-K.....
thats how decs is gonna make my cooler piping, looks like shite, but atleast its much shorter...
Kye, can you link my aquarium to NS.com for me dude?
cheers
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...=STRK:MESELX:IT
just did it craig
http://www.nissansilvia.com/forums/index.p...howtopic=419835
Does anyone know if regency will accept R32 GTR front brakes instead of R33 GTST front brakes when registering a 25'd 32?
Here is the part about that in my letter: 10. That Nissan R33 296mm X 30mm disc brakes and calipers are fitted to the front axle.
If I have to use them its fine, but my understanding is that brake wise R32 GTR > R33 GTST. Maybe I should give them a call and ask..
I think r32 gtr non-brembo brakes are the same as as r33 gtst brakes anyways
ugh. went to the dr's about my sleeping and anxiety issues, instead of finding a solution, "heres some drugs, enjoy." f**kin.
anyone got suggestions on what torque to do a hubcentric bolt on spacer up to ?
110nm + some loctite.
asking for a little help
posted in borrow section too..
me 'na mate are rebuilding a suzuki f5a 543cc 3cyl hatch atm, engine is out on ground
cant get the flywheel off, etc.
need to borrow a flywheel stopper holder lock tool
anyone?
anyone?
rattle gun works a treat ;D
Guest
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
