  • Replies 14.2k
\m/etal. get andrew to make it up for 150 or something. found my hks one on a 2nd hand engine at jis for about that. ha.
... or just buy that ebay one. i would.
good value for money , even my engineer said it was good quality.
comes with all silicone and hose clamps aswell
silly question but does leaving your car in 1st and turning the car off do damage to anything.
oh nooos..... you have def blown your gearbox now,
you had better sell it to me as a spare...i give you $50.
Progress Report:
Luke and I got the tiptronic box out of the Stagea today ... those things are f**king heavy!!!
Next step is to fit the Exedy flywheel and clutch kit to the crank, then put the manual box in place.
Thanks a bunch for the help so far Luke. >_<
At least Stags aren't like alot of old cars, with two different cranks for auto and manual. Good to hear its all going well Ruby.
Well JJR delivers once again. Fitted my Autech copy catch can and my ARC copy washer bottle/catch can today!
While I'm here ...
Can anyone tell me, or point me to a link, as to how a GTR/260 gearbox pull-type clutch fork mates up with the pull-type clutch kit, so the clutch engages properly. Push type I know you just slide things on. But is there a trick to fitting the GTR box to a pull type pressure plate and carrier?
Thanks >_<
Guest
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue.
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
