  • Replies 14.2k
my glove box won't open, anyone got any ideas how to open it without smashing the lock???
when u put the key in it will lock and unlock but when u pull the lever it won't open
the lock it self seems very loose when i have the key in and clicks when u turn the key
any ideas...............
unscrew the hinges from the bottom of the glovebox. once theyre off you'll be able to unlatch it from the striker
-D
All this talk about the new applebar.
Must say it does look the goods.
Not too many places playing decent house/tech/prog etc. Fumo has some good tunes sometimes. Not loud tho. Sugar used to play decent tunes. half the DJs are on smack playing now tho.
Will deff check it out one night for sure.
anyone know where i can pick up a silo diff?
also i cant seem to find the general parts section on r31club!?
cheers
not sure, but if you ever need one rebuilt or converted, speak to graham at boss engineering @ lonsdale
dude did a wild 4:11 LSD for my old 31 that was unblvbly good.... wasnt cheap as I did a total rebuild but im sure he could custom make something based upon the stock diff housing that'd suit your budget
-D
cheers
You need to be a member on the 31 club, and have a minimum of say...5 or so posts.
Remember, any price that is posted, you can demand for a fraction of that price and get them to deliver for free :laugh:
Ill have a quick 'skwiz' for you, and link you to anything that comes up. Assuming that you want it from South Aus?
sick.. i will pay $200-$300 ish pending condition..
and adel would be awsome!
cheers
got msn?
[email protected]
Yeah he has, took Lukey for a spin in the R with scandy a few weeks back. We'll convert him :)
Got a bit of work to do :laugh:
RBs need more torque.
Also......need money to get a skyline. Something with a 30DET would be nice...if i could afford it.
Edited by P1RATE
Guest
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
