  • Replies 14.2k
I work for ETSA aswell from marleston there were a few rumours getting around still funny
ah k, which part of marleston? supply restoration, CBD or Substation branch? Got a few mates spread across those areas
I dont know... something RB26DETT, AWD, has a GTR badge on the rear and preferably between the years of 1989 to 1994 and in gunmetal grey, white or black.
Oh. I've heard about those types of cars. Apparently they can be fun. Did they come in black?
Anyone know a place to get a car properly cleaned that has been sitting in the elements for too long and needs some real TLC? I was looking at the place on Unley Rd and just checked out their website. Seems fairly pricey. Anyone used them and were they happy with the results?
randomly searching around tryin to find price for a tier 2 vehicle identity inspection, stumbled across the new VIS (Regency/Lonsdale) Vehicle Inspection fees..........defect clearance just got epically more expensive!
http://www.transport.sa.gov.au/pdfs/878Veh...eeIncreases.pdf
read that it says as of 1 july 09.........anyone been thru of late that can verify?
Edited by Matty 31
theres a place opposite charminars that does hand detailing for the $50 mark iirc, I prefer to clean it at dazzlers myself and then let either prestige or lex do a detail for me every few months
-D
Now when it says Second Inspection does that mean for the same defect...or next time the car goes through.
think thats where u go and you've been given more things to look at / rectify......so second visit essentially. Dont think they've got a "frequent visitors" discount...........yet :)
$143 sounds rite to me, never had to go back a second time though.
lol Dale means more money for petty to go driving :)
True but the 180 doesn;t have an engine in it ATM and i dont have the street car that's running either. And i'm still getting knackered at the drop of a hat so i'm still to sick to fix either of them. but i am really saving money because there's no alcohol or petty to buy.
Going on an impromptu cruise for GTR's only.
PM me before 11am if you want to come. Meeting in a specific location at midday and then cruising the hills for 2-3 hours.
Numbers are limited, and entry is restricted to GTR's. Sorry, but thems the breaks. After 11am tomorrow I'll be driving and wont have time to talk to people, so if u got stuff all else to do tomorrow, have a gtr, and have the petrol, msg me.
No exceptions.
-D
awwww.... but i wanna play with the cool kids. :(
looks like its going to be a raging success. :)
lol, but i dont lose oil pressure and spin a bearing...
hows the running in going?
well now that you've just jinxed yourself... =P
eh, painful, still another 400km to go and BW closed till some time next year so have at least 3 weeks more of it =(
Guest
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
