  • Replies 14.2k
you could prob take off in 5th with the 25
and still cane the 20 taking off in 1st :)
ahhhh.... why am i putting a 20 in the 31?
20 can be ok just ask inspect-a-gadget he built a very tough 20 with a worked td05 heaps of custom work in a R31 wagon with 250 rwkw
yer she will be ok for what i need it for.
Fabs32 had a vg30 on his 32, made decent power, and boost come on pretty early, does some
pretty good slides too...
if a full street trim 32 can do it, my stripped 31 can.
Ofcourse the 20 is a good engine, its just easier to start off with the 25/26 because you already have that bit more capacity to make use of. My main motivation for going 25 is because I couldnt find a decent 20 lol (ie. not needing to be rebuilt now or in 6 months)
And so will my striped Ceffy. Just need a set of S13 coilovers and a diff that will spin both wheels unlike the one in it now that will spin 2 when it wants to :) and i might need a bigger turbs than a standard 20 cos the turbs on it now seams to run out of puff up in the revs :(
ugh. people shit me.
got my wheels advertised on 3 forums, got a pm on one of them asking me if im willing to sell just the rears for $750...
1) that offer sucks harder than a thai hooker.
2) what the f**k am i gonna do with the front pair? make a f**king coffee table?
Edited by scandyflick
Was walking down hindley around 3am this morning. I see the undercovers 4wd, cops jump out to help with this fight. One guy who was involved in the fight runs off towards me and 5 cops chase after him down hindley. My mate kicks the guy in the leg, slows him down abit, cops still chasing him, tackle him from behind and the guy goes straight to the ground. Everyone cheers.
was this near the lights, i reckon i seen it aswell. only seen some sort of argument from the dude trying to cross the road the car coming through. not sure who was in the right but then he gave his car a boot to the rear quarter. was already dented but the driver seem unhappy about this and went on to finger point for 5min. i figured there wasnt gonna be a fight and went on my merry way. .
also xmas hat got me a pic with a f ing hot blonde who demanded her pic taken with santa :)
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
