  • Replies 14.2k
got more details on the head work please???
No idea really, besides whats in the link
ahh nice!
gotta be happy with that!!
i'm making the same power with an unopened motor :rant:
Yeah considering the temp in their dyno room yesterday its pretty good. cooler day and with their a/c fixed, and a boost controller that'll hold more pressure, should be able to get atleast another 20-40kw out of it :(
woot woot new clutch has arrived.....cannot wait to slap it in and not worry about 3rd gear slippage :D
also very very nice power figure there James.....cant wait to see what mine will be making once all is fixed and retuned.....close to 270rwkw hopefully :)
Chad,
Jan 16th
coming?
I'll try and make it for sure, i've finished work for the year now so i'll get stuck into the car. Few problems i have are, turbo is nearly dead, diff spins one wheel at times, handbrake does nothing at high speeds. suspension is nismo struts with cut springs :D If i can get a few of those things fixed i'll be there.
Who's fitting it Krishy :)
Hmmm, I need help putting in my new clutch, with a freshly machined flywheel, redline gearbox oil, castrol transfer case oil, rear main, spigot bush, and C's short throw shifter? Know anyone Luke lol!? :D
Std carnk and rods, 50thou over N1 pistons, serious head work, 2530's, 750cc injectors, ah i'll add the link its easier
http://www.skylinesaustralia.com/forums/60...html&hl=GTR
Nice pick up there James, lots of serious mods too, must of saved a packet in the long run, be good to her!!!
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
