  • Replies 14.2k
What size rear has the turbo got Abe?
I think the Garrett 3076R(3037S) is a 0.82
little bit of a lean spot there at 160kph....just monitor your knock count
Are you talking about the 262kw graph or the 149kw graph?
If the 262kw graph, if i am not happy with the tune i can take it back and get it touched up for free :), he didn't really have much to go with as it was a whole new tune, so he got it to where he was happy with it and gave it back to me. If there are some niggle bits i am not happy with, he will sort it out, see how we go on the way to Loxton. But i will rarely be driving at 160kph, if at all.
u can see the lean spot in the first 149kw graph that you posted. there is a big drop in the afr line.
ur new tune looks good :)
Ah...well the 149kw graph is stock...stock everything other then a podfilter.
just bought an RB20 + gearbox + FMIC + ecu, afm, loom +3'' zorst for 1100.
bargain? yes.
entirely happy? no its missing .5 of a liter in capacity but oh well, its a budget build.
specially when its gettin fitted and wired by a effing champ in swaps for the RB30 :)
cant wait.
pretty keen to build it up in almost every area, inherited some pretty average suspension in the car so probably looking at coilovers as my first upgrade. gunna go for the BC br range i recon, cant seem to find any negative feedback on them and they are sweet price.
buy decent quality straight off the bat. please. save for an extra week or 2 and buy cusco's or something.
.82 rear, thats why its a bit laggy, but u got more topend out of it
since u cant check ya knock level reading just keep an eye on ya engine warning light, if it starts to come on regulary after a boosting hard step off and getnya tuner to check everything again (timing)
bargain? yes.
cant wait.
nice deal Graig
and who is this CHAMP that is wiring it up for u??
fair enough, might have a look into it a bit further. im normally pretty keen to do everything the right way. to me these coils looked like a fair deal.
Guest
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
