  • Replies 14.2k
matty i got quoted $2200 for a internal gated 3071r with lines.. that was mtq
Depends what you want i guess, Internally gated or External.
GT3071R Dual BB rated at 500hp, $1,815
GT3071R T25/T28 Internally gated with a .64 rear housing, $1,795
GT3071R T25/T28 internally gated with a .86 rear housing is also the same price as the one above.
Courtesy of Tweakit.com.au
i want a 3071r internally gated suited to rb25det..
with braided lines..
External man! Get a V-band wastegate provision welded onto the top of the manifold, screamer, heaps better.
Internally gated screamers are like putting socks in your undies :D
Internal gated screamer for Age it is then!
the original bridge builder there is one that runs a train over your bridge after great fun
>>Bridge Builder<<
or this but i cant even get past the first level
http://www.engineering.com/GamesPuzzles/Br...72/Default.aspx
http://www.chroniclogic.com/pontifex2.htm
Evening all,
Anyone know what time Boostworx open? I know Shaun has moved out to Cavan, but cant find the hours anywhere.
Thankyou in advance.
at a guess open at 9 close round 5:30... but im sure shaun will be there a bit longer than that
Trying to get to the battery in a R33 GTR. What gheylord decided to put a serviceable part behind a strut brace and under a speaker? The bloody speaker magnet keeps grabbing the tools and I can't get the strut brace undone. So far I've been hitting a spanner with a mallet but all that has done is give me a headache, annoy the dogs next door and dent the spanner.
It's not even my f***ing car! :D
Guest
