will look tuff as nails on a HR31 for sure.
bundy...horrid? do you even have any taste buds?
whats do you drink? teds?
i got solid taste in drink. lol.
after work, teds get a pretty solid hammering (5 squid a pint, cant complain). my usual weapon of choice is cc dry.
when i want something different, ive got bottles of small batch, gentleman jacks, makers mark, other rad stuff like that.
and when im feeling really fancy, 22 year single malt glenfiddich, on the rocks (no more than 2 pieces of ice though).
Edited by scandyflick
  • Replies 14.2k
  1. Chad
    4. Safety 21 half cage for A31 Cefiro / C33 laurel - good nick, all bolts and mounting plates - $600
    Contact Dan on 0413 761 305
    i kinda know him, so can possibly get it cheaper
    I has sun roof :D
Edited by DSTROY
Wow ... was looking for something and stumbled across some old AIR time slips in my old race leathers from October 2004, from when I was drag racing bikes. :D
I've had these leathers 6 years and never wore them again after AIR shut down. Zipple (Motorplex) cruise tomorrow ... coincidence?
thoughts??
i think her body is smokin!!!
a little on the ''too toned'' side, but fit as!
missus was just watching her dvd and dayum........ needed a long (well short) shower lol
specially when she did ''i touch myself'' wow
thoughts??
A pretty talented chick, I dont really get into pop but at least her songs arent painful to listen to (and she seems to have a brain on her head...)
As far as attractive tho? Nah... little too dykey
I like curves n boobs
ala Laetitia Casta
Keep dreaming Doh...keep dreaming...
-D
Hey guys, I am having a sausage sizzle at my work tomorrow (Australia Day)
& I will be driving the R35. Any of you in the area around lunchtime are welcome to
cruise past & say g'day & grab a banger with sauce.
Guest
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
