  • Replies 14.2k
hence why i dont have passengers usually in my car during cruises.
Even though my car feels like crap with other people in it, it's not worth the risk at my age. Media would go nuts too.
poor kids though.
So, here I present to you, the good people of SAU, another chapter in the epic saga of trying to get my Silvia back on the road.
I left the last chapter having discovered that no other RB that anyone I know has seen runs V belts, hence my harmonic balancer must be the wrong one. I had high hopes of being able to simply remove the balancer off my old 20 and chuck it on the new one and presto - no more wobbling balancer.
Oh no, not on this car, that sort of shit would be too easy. No, instead me and a mate have gone to undo the crank bolt holding on the balancer (after a mass headscrew trying to get the rad out to make some room) and it's loose as a goose at first crack. Undo it some more and it starts to get tighter. Throwing caution and possible snapped/threaded crank bolt to the wind, we continue to undo the bolt, having to put more and more force into it as we go.
Now a good hour of this and we have almost got the bolt off but it's fking tight. We pry the balancer away from the engine and it's loose as. It also turns about 20 degrees on the crank. At this point we're thinking 'that ain't right' and lo and behold the key locking the balancer onto the crank is moving around, clearly locking 5/8ths of fuck all.
After another few minutes of trying to get the bolt off to have a suss of whats left of the locking key we give up, my mate goes home and I come dangerously close to grabbing the matches and petty again.
So, I finish this chapter with:
1 I almost definately have the wrong balancer and as a result the key that is supposed to lock it so it turns with the crank is fucked
2 the crank bolt feels like it is nigh on snapping
3 I'm nearly at wits end (again) and have either a for sale ad or a large bbq in mind
My next port of call is taking the balancer off my old engine and using it, and it's locking key, on my new engine - IF I don't snap the crank bolt before getting the fucked one off. Once again, if it works there will be many skids done in celebration. If it doesn't there will possibly be fire.
And you really did miss out, i ended up jumping in with Kristian in his EVO VIII (Thanks for the lift). So you could have gone on the cruise and got to ride in an EVO.
Could you hear the cars from Rundle St?
not really i had tripple j hottest onehundred up pretty loud on the sonos surround sound. SSSPPPEEEWWWWIN i hate missin out! once again thanks so much for the the thought mate!
Andrew, sounds like you'll have to replace the key at the very minimum also but if the new key moves from side to side in the slot even slightly, you can kiss your crank goodbye.
Can be taken out and welded though, but probably wouldn't bother and just find a second hand one.
Get that balancer off 1st before you go burning it, lol.
agreed as ive recently discovered a crank, key and harmonic balancer are three very VERY important componants that need to work in harmony :)
wow, part of me is sooooo glad i f**ked that engine off, and part of me is feels bad for selling it.
just goes to show, when buying a 2nd/3rd/4th hand engine, ya never know what its gonne be like.....
want his address Andrew?? :)
Now a good hour of this and we have almost got the bolt off but it's fking tight. We pry the balancer away from the engine and it's loose as. It also turns about 20 degrees on the crank. At this point we're thinking 'that ain't right' and lo and behold the key locking the balancer onto the crank is moving around, clearly locking 5/8ths of f**k all.
1 I almost definately have the wrong balancer and as a result the key that is supposed to lock it so it turns with the crank is f**ked
how on earth did it not censor those words....see if i say f**k it is censored to F**K
Your boys getting big Craig!! How old is he now??
aww she's adorable. how many teeth does she have, i can see 3 i think, lol.
Amber only has 1, can't really see it though coz she only just got it.
this is Amber on Aus Day
oh lol, Amber is a proud owner of a Subaru WRX thanks to her uncle Jason haha
woot just bout a hks low mount cast exhuast manifold with external gate!
turbo check!
afm check!
lines check!
wastegate check!
gauges check!
injectors - waiting on.
fit almost!
woot!
Guest
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
