  • Replies 14.2k
Just finished watching Paranormal Activity, f**k me that's a scary film. Not usually one to get a scare out of those films but this had a few moments for sure!
Was that a DVD screener? Seems weird that it was released in 2007 and my usual source for a movie only has screener versions.
Spot on, exactly the same as the theatrical release save for the alternate ending. The film actually wrapped near on 3 years ago, just a small low budget ($15000USD) but a fresh and original horror flick :blush:
Talking to a mate over the phone last night whom I haven't seen for a while and he's telling me about the R35 GTRs that he has spotted around Adelaide. :blush:
You gotta love it when your friends share in your passions even though he's never even been in a Skyline.
is any one here a metal worker?
i need/want a peice of sheet metal cut to size to cover where my rear seat used to be....
chad?
Pretty sure Chad should be able to help you out there Craig.
chad?
Give me the size's and i'll see what off cuts i've got laying around the work shop.
Guest
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
