  • Replies 14.2k
Driving to Balgowan today I releasised what a pussy f***ing limp dick car that I drive.
RB s are gods. My pathetic little 3.5 is the eqivelant to a 3.5" penis.
I wish I owed a GTR. They are sooo cool.
lol. its not horrible. but does require 6 or more psi to make it decent.
lol
andrew left himself logged in on someone's computer i take it :blink:
soo, car will be finished inside of 2 weeks :blink:
then i stupidly asked him for an estimate of the final bill....
so i went from :cool: to :D in a matter of bout.... 4 seconds... Kinda reminds me of when i was learning how to seks
yer, now my missus is gonna tear me a new anus when she sees our term deposit acc. has been raided :blink:
on another note, i stole this from ns.com
i likey this thread alot, pretty sure i have seen all parties involved on here before,
so beware
http://nissansilvia.com/forums/index.php?s...;st=0&fcat=
enjoy.
wow, i just found out that Autech have had a fiddle with nearly everything in the nissan range. theres a guy on the patrol forum from canada with the Safari (overseas model, basically the same except they didnt skimp on the turbo on the 4.2 diesel LOL), he's punched his VIN into the Nissan FAST system, and it spat out that the vehicle was built by Autech, and to contact them for information
http://www.terra2imports.ca/import-japan126384684160397.htm
yes Autech is awesome now put your tounge back in your mouth :cool:
i has a spare gap in my car, what to put there :blink:
Guest
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
