The Sa Wasteland
heslo
 Share
  • Replies 14.2k
kids isnt that a club sponser there? depends what you buying there, walk away from the neon and tail light section.
i usually get my oil from the autobahns
forgot about that hahaha
some of the things they sell there shouldnt be sold
Man apply at PPI on night work. will be on about $700 per week. Its down at Ottoway
awsome cheers man. How do I apply for them? On the net?
On my iPhone so can't be f**ked looking for ppi atm
heading back to school full time just need a few dollars to keep me alive.
hindley street corner kye, earn those $
also whos gonna be the first to get 1 of these
http://www.cardok.co.uk/index.php
Been there done that. You don't pay me enough.
Well when the 3L gets built and the gtrs's strapped on I'll take it down the quarter.
if we had a drag strip id be taking it down before and after mods to see how much quicker you get. beats comparing kw figures if you ask me :)
wow, ns.com is sooooooo hardcore mang.
make one comment, and they twist it into something utterly stupid.
uughhh, ill just sit back and lol from now on.
and whats even worse, they must scroll right past the 'useful' info in an effort to hurry up and
get to the fast reply box in order to be xena warrior princess of keyboard warriors.
/rant.
Edited by craig R33
i still need... you free in < 2 weeks matty?? not sure of exact day, but ill be on holidays atleast :P
depends mate, depends
my next RDO is 22nd feb. would much prefer it if it wasnt so hot atm though, the poor old patrol is suffering
Guest
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
