  • Replies 14.2k
think i need to clean the rubber off the Ceffy and you can see where i gave the tyre's a tap coming onto the start/finish straight, fair lucky not to lose the rear bar.
Edited by DSTROY
Gtr as a daily 34 as a project.
theres several interesting 32 gtrs on carsales atm
one is #78 of the original aussie delivered 100
one is a tommy kaira spec 32
and another has only 9800km on the clock...
whats ur budget? :D
-D
whats ur budget? :D
-D
I so wouldnt mind that TK R32 GTR... but its so ugly and not in my favourable colour.
Excessive lowering will give you too much toe in, unless you have adjutable upper arms
stock suspension now and stock arms
only adjustables that were in it were coilovers and rear camber arms
will have to put hicas back in
could that be the problem?
Proves that you are driving it properly!
it can affect hicas if the toe is greater than 2' on either side, the hicas computer senses it somehow and disables hicas after about 15 minutes
for what its worth, i got some rear adjustable upper control arms last year for around $350 and the precise adjustment that the aligner was able to make more than justifies the cost... makes the car perform much better with less tyre wear to boot ;D
not regency friendly, but theyre easy enough to get engineered
-D
-D
i think you'll find what ive had to remove :D
Is that all?
*sigh* its enough to throw his geometry all out of wack again
he has the front castor arms, the rear camber arms, the adjustable suspension... all 3 things that work in tandem to ensure the suspension actually works properly
u should enquire about getting that stuff engineered man, rory thompson does it for $500 odd if I recall correctly, and that mean you could continue using the control arms for caster/camber... not the suspension but eh, 2/3 is better than nowt
-D
Yeah my suspension was out of whack when I removed everything for regency, handled like a bucket of shit on the way to Tyre Power for an alignment which straightened everything out and made it feel perfect again afterwards.
Guest
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
