  • Replies 14.2k
LOL at cutlery unification .... at the long-gone "Fairview Park Chinese" shop the old Chinese lady used to always ask when she presented your takeaway meal "You want spork"? And they were sporks too.
Me. I had Pete from PLMS do a quick road tune of my car once he installed the nistune daughterboard. Was good enough to drive home safely but he was quick to stress that a road tune is no substitute for a proper dyno tune
-D
actually a road tune with proper wide band sensor is better than a dyno tune but you have to be able to load the car up
Must be the day for old ladies to occupy all tellers at the bank :)
Another thing I hate ...
When you approach a red light, your lane is free, then a car from the other lane (with multiple cars) at the last minute moves across to get in front of you at the front of the lights. Then when the light goes green, they're the slowest car at the intersection. Why the f**k do they position themselves to pass the car in front of them, then proceed to not pass anything when they have a green light. ;)
And my vote also goes to the f**kwads who drive 60 in a 70 zone (or 50 in a 60), then just as you're about to pass them in another lane, they move over into your lane without indicating. :)
Happens on a daily basis Ruby. I had a moron flash his high beams and lean on the horn at me because I was doing 60 in a 60 zone and changed lanes in front of him while easily 2-3 car lengths in front of him. And he was in the right lane doing a max of 50.
Nearly every morning on the Port River Expressway there's someone doing 70-80 in the 90 zone and yes usually they're also in the right lane. Pretty sure a car got pulled over this afternoon doing about 60 in the 90 zone. Then there's those that change lanes without indicating, slow down at intersections (maybe waiting for a red light...?), those that speed up on yellow signals and run red lights, those that can't drive straight in their own lane and wander into both lanes, use the 3rd lane (the ones that merge into 2) at some intersections and then go slow enough to have to stop and allow traffic to their right pass..... and all because here in Adelaide there's too many fktards allowed on our roads. I could go on....
Guest
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
