  • Replies 14.2k
32's and 33's might be getting a bit old but still has modern technology behind it....look after it and it will look after you
how hard is it to change the harmonic balancer on a RB25???? *looks at dale*
That's just the thing. Their old and finding one that has been looked after well is going to be hard.
Seeing as there cheap now aswell, more young people would own them, thrash them and not look after them.
Sure they have some modern tech init but so does an evo and probably more too.
Just would want something newer.
Each to their own. I personally wouldn't touch anything domestic and if I had to it'd be a Aurion/380 or Magna
My mom also wanted an aurion but when she got one as a rental she didn't like it.
Nothing wrong with domestic cars. Parts are easy and heaps of people that can work on them.
But when I am going to look for another car I'm looking at moving up with something newer domestic or import I really don't mind as long as it newer then what I've had low km and some proof of it been taken care of. Nothing against 33 or 32, shit I've owned both. Just want to move up in the car world haha.
This is true, how many VE's will be on the road in 15-20yrs?
We both know what the quality of domestic market cars are Steve, especially GMH :cool:
But how many commos will have less then 150,000km in 15-20 years like the majority of 15-20 year old imports haha
I don't like holdens but a new car is a new car to me :cool: plus I would want to off load my cars every 2 to 3 years for something else I can't stand owning a car for to long for some reason.
Still want an f6 typhoon or an evo. Evos first choice though :)
And unfortunately I'm bound by confidentiality agreements with both GM and their suppliers I do work for so I can't really say much more....
I don't like holdens but a new car is a new car to me :blush: plus I would want to off load my cars every 2 to 3 years for something else I can't stand owning a car for to long for some reason.
Still want an f6 typhoon or an evo. Evos first choice though :yes:
yeah have to agree....never used to like EVO's but they're growing on me as they are an absolute track weapon and one of the very few cars that GTR's struggle against at Malalla and Hill Climb events.
fairly sure i seen these rims on a certain red S14 in the past
http://i142.photobucket.com/albums/r102/cr...e0023Medium.jpg
and youd be right. look a shit ton better on the 31 than they did on the 200.
Guest
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
