  • Replies 14.2k
yeah 044 is external, the nismo ones i've seen for >600 so they're out. 33 GTR pump will drop straight in but i'm expecting Nissan to give some sort of shit pricing.
What trouble did you have with the 040 Abe? Hardest part of the install looks like positioning it close enough to the bottom of the tank.
Edited by nicr4wks
sscond hand gtr pumps go for $100-$200, modify the cradle a bit, and youre sweet. can buy brand new walbro pumps for about $160 from ats, basically the same to fit as gtr pumps, minimal mods and it goes right in.
Edited by scandyflick
Yep I highly recommend the Walbro 255lph - had one in my S15 and my R34. The 040 I had in the S15 sucked up silt off the bottom of the tank and blocked, then failed.
Pumps with socks (like the stock pump and the Walbro) are better designed for Nissans IMHO.
Also, got camber? I have some camber arms ordered to address the problem, but it looks pretty slammed at the moment :D
haha ill take this stagea anyday!!!! http://www.discountusedcars.com.au/used-ca...ea/3483209.aspx
lol someone didnt get enough sleep! or am i misinformed haha
hahaaha at least its an autech
Anyone know roughly what a 33 GTR fuel pump is worth? Or should I just drop in a 040.
i have an 040 was already modded to the cradle so i just dropped in :D
hahah nice Andrew
i go to AutoPerfection tomorrow to have my splits fitted, any one have questions
alarms, installs, tints, what colour undies to wear :D
shit balls. thats crazy.
are you feeling the blue or the beige? im leaning towards the blue at the moment.
getting them to fit is f**king simple if you have a dremel and hose clamp. i was a bit confused when i did mine, but then i looked at went "ooooooh", 30 minutes later it was in the tank.
+1
i rate the walbros, very simple to install, and they do their job well. there's a lot of mixed opinions around other areas of the forum on these, but we chose it over the bosch for its similarities to the std setup. installed, tested, and proven good performer.
fuel pumps arent hard to install if your not afraid of modifying the cradle, getting a few cuts on your hands from the fiddly bits around accessing the tank, and of course inhaling petrol fumes :D
some like to go that bit further and rewire for better voltage
would look even better with some 25mm spacers ;D
only concern I'd have with the wallbro pump is whether or not it flows more than the stock gtr pump - i know this isnt much of an issue till u go over 300kw but I'm leaning towards the nismo (125% flow rate) rather than a bosch
what splits are u getting steve? type R's ?
-D
the stag has had an 040 for 4 yrs now, no issues.
the rb26 sedan has an intank gtr pump and fitting an external walbro 305lph unit - $160 good price
040's are around 190 but you can get copies for around 100
Guest
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
