well, went test driving a couple of cars today for my mum, lookin to replace her mighty corolla. thought she was goin to be set on a Hyundai i30 CRDi, but it seems we found something more european second hand with minimal k's thats better quality
http://hamilton.deadline.net.au/aspx/searc...amp;loc_index=0
  • Replies 14.2k
at the moment, yes, but unofficially. theres still 90,000 odd votes to be counted. if theres enough liberal votes in that 90,000 odd for them to get another 2 seats, itll be a hung parliament.
I dont get how Labor can be celebrating so much.
They are now the most un-popular sitting parliament in history.
With the massive amounts of swing in the electorate, and they are raving on about how good they are..
Liberal even got more votes than them, according to the sunday mail!
Yes, if you look at the results, The Legislative Council vote results show that 292696 people voted for Liberal and 282663 voted for Labor. But Labor get the win as more people voted for them in the regional votes - more seats.
Speaking of politics, saw some guy on the side of the Southern Expressway this morning with a sign saying "Thank You" and waving to cars.
Looks like im gonna return the 2.5L swirl pot and go a bigger 5-6L swirl pot to be safe :blink:
So i dunno if someone wants to buy it off me or i can return it but its a 2.5L pederson swirl pot. Think it was $175 but i'll double check tomorrow if anyones keen :ninja:
so your buying genuine starcorps this time?
yes. yes i am.
thinking te37's or cr kais.
rota knock offs though, of course.
Am i a whore?
<snip>
I really need to sell a couple of sets.
i think you could be accused of being one, yeah.
Democracy is a myth. Don't believe the hype.
i dont.
So anyone been watching The Pacific? f**king awesome series!
nope. worth acquiring?
Edited by scandyflick
lol ok damo authorised romote access
wasnt anything fancy, just a home made reverse vnc single click utility designed to go thru my firewall and connect to vnc viewer in listen mode
pretty easy to make, and is only 150kb in size
-D
Guest
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
