I'd probably weld it too if it can be done successfully....forking out $1500 or more for an aftermarket job just to gain approx 5rwkw aint worth it IMHO
only 5rwkw? i know cubes says its one of the most important upgrades for the hybrid RB30 engines
im not saying luke should do it for the 26 and if he hasent go the money for it now, of corse try welding it up... but it should be something on his list of things to do for the 30!
  • Replies 14.2k
The difference is going from the standard RB20/25 over the top intake manifold to a front facing manifold then there would be gains to be had, but Luke's manifold is a GTR manifold and there are plenty for GTR's making up to insane amounts of power still using the factory GTR manifold.
The Greddy and hypertune manifolds will give you slight increases in the top end when you are making massive amounts of power but you will be getting this gain at the cost of low down and midrange power, and like SLED said your only talking 20-30HP gains on a 700HP engine but your are losing like 80HP below 5000rpm
Edited by D_Stirls
Well my Maxima plans may have changed
http://www.carsales.com.au/all-cars/privat...s=&__N=1216 1247 1282 1252 4294963846 4294963593 901&silo=1011&__No=45&seot=1&CT=Compare&__Nne=15&__sid=124A2A3AA132
Me likey veeeerrrrryyyy much :thumbsup:
that is nice James, definitely check it out! a lot of goodies listed too
seriously couldn't picture you in a maxima mate... haha
just bought one of the turbosmart boost tees :thumbsup:
and on another good note, the 31 goes to its new home today!
Kocking off work at 1, rush home to wash/detail my cop of a car then race down to the showgrounds and setup the SAUSA display! what an arvo.
Haha yeah think im missing the 33 like you missed yours. Got a few guys to talk to about it to get a bit more history on it, but the guy that owns it use to work at Autobarn.
I may even be taking it out of context, it was a while ago i read it and perhaps it was just about 20/25's and i read 26's into it, but without actually finding the post im pritty sure it was also including (if not specifically about) 26's and it was sugesting a particular brand and not greddy/hypertune... and coming from an rb30 guy that knows his stuff so i'd take his advice, or at least strongly consider it, if i was doing any kind of 30.
in the end, its lukes car, lukes money and lukes goals so he can do anything he likes. i was just reminding him what cubes had said
absolutely!
and hey, did i read correctly last night on FB - the little yellow weapon is finished!!!!???
just bought one of the turbosmart boost tees :)
do you mean the turbo-tech ones Damo? thought you were having issue with the t-smart one
i second the turbo-tech tees like the others here, had one on my white 33 - held 11-almost 12psi up to very high revs. The Mines ECU had set the limiter @ just over 8000rpm too :thumbsup:
yeah i mean Turbotech :thumbsup:
my current boost curve drops off a fair bit, from 10psi down to around 7 by redline. holding the boost higher through the revs with the new boost tee will obviously affect my tune wont it?
yeah i mean Turbotech :/
Just got my siemens-deka 575cc injectors from the US for my GTR.... total cost? $360 for 6... cant wait to get em fitted... cheapest injector upgrade ever
-D
I wore boardshorts to the office today.
Fingers crossed I get sent down to parliment today to fix some sort of computer issue.
The ministers will love me.
put some sick german porn on koutsantonis computer and call today tonite
'omg laik wot a sicko is this guy'
-D
EBC FTMFW
Guest
    • I like the idea of tagging the model, and if GTS-t/GTt or GTR, and then a what, so wiring, engine, suspension.   That way you end up with a matrix, all content R33 GTST, or you can find all content that is wiring related for example.
    • You could probably just go with the genuine Nissan pads, they are not really the expensive, I can't say how they compare to your 350GT pads but at least they will give decent performance. Shims are probably the reason for the squeal.  When I bought my Q50 which runs the same Akebono brakes, the previous owner had some weird pads fitted and it squealed and dusted like crazy, I bought genuine pads and when I put them in, I found all the shims missing.  With the factory pads, the dusting is much better, performance is fine, but it still squeals when cold.  A bit of grease on the back of the pads and mounting points gets rid of it, but it comes back after a while.  I have bought a genuine shim kit that I need to install when I get around to it, hopefully that will fix the squeal.
    • Highlight that row, and a bit of trial and error. Try reducing it by 25% and see if it starts, if not, go the other way. On the newer Kebabtechs that table is in VE which makes it so much easier to calibrate.
    • That's the one I have in my R32. There isn't a bigger battery that will fit an R32.
    • Not sure what you mean haha. That one doesn't fit mine but when I get sick of my one I'll get a standard one. I just gotta find a way to make it fit cause some shit is in the way.
