  • Replies 14.2k
woo! got my fog lights! couple fuses, a relay, a switch, and some wiring and itll be good to go. should have my front bar by tomorrow as well. rad.
lol. wired the lights in. piss easy. just need a switch now.
thatd be awesome if you could. cheers.
dave, have u got a blanked spot(s) in your dash like i do
if so, i recommend one of these: in the link its the 63027BL (bottom of the page, left hand column)
http://www.narva.com.au/products/browse/standard
HAPPY 21ST BIRTHDAY
TO MY BEST MATE DION
AND TO DAVE
MWA XXXX
Happy Birthday to the double D's - Dave & Dion.
sorry to hear Kellie
happy birthday DD something for the lol's
Haha Madaz. Thanks alot guys :down:
someone just tried to break into my house,lights on im in the lounge and they cut the screen to my kitchen window i have just had 2 cops here actually really scared and want to vomit
Jeez, sorry to hear Kellie, hope your alright now. It shits me when people try to break into houses when its obvious there are people inside (ie. 2 cars in the driveway). Do they get some kind of kick out of it??
it wasnt long after i spoke to you babe that it happened i wanted to call you or james but i seriously couldnt move when i herd the person cutting the screen on the kitchen window
Guest
    • Hi Everyone, I did 4.11 gears in my 34 GTR and only thing that remains is to fix the speedo reading (it reads about 15% higher) using the R33 GTR speedo sensor. Few questions:   1. Does the R33 speedo sensor fit right in to the 6sp getrag? I read it does but wanted to confirm because the speedo sensors between 33 and 34 look quite different   2. The connector on the 33 speedo sensor will not plug into the connector on the getrag. Do I just need to wire the pins together manually?  See pic: https://imgur.com/a/NTDzFe8
    • Does anyone know how I could find the part number for bolts used with  r34 with rb25detneo engine lower timing belt cover?   my timing cover was rubbed and i fixed it but upon putting the harmonic balancer i see the timing cover is almost rubbing and that is due to previous owners using general bolts and washer rather than the bolts per link below which sits inside the washer and pull the cover in   not sure if those bolts will fit rb25   https://www.ebay.co.uk/itm/326510870741?gad_source=1&gbraid=0AAAAAB_7XZxjuciMybdVOTShCs9857686&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338723872&toolid=20006&customid=7jIl12glAAAAVfHSSnyxAmSsdRxnAAAAAA
    • If the slightly higher internal EGR caused by a high flow cat causes detonation your tuner was way, way, way too aggressive to begin with. Timing scatter is a problem unless you go to a crank trigger, winter vs summer blend has different octane, list goes on.
    • The H1 Alpha with the 6.6 Duramax is basically the actual powerplant it needs to be remotely ok to drive on public roads. It's just not worth the cost to buy a real one. Humvees look cool but man the reality of them is depressing. Grunts aren't kind to them but they aren't that reliable either, they have horrible payload despite absolutely massive size, zero actual armor against mines/small arms, absolutely anemic naturally aspirated diesels, list goes on.
