  • Replies 14.2k
RB25 run 9.0:1 static compression standard and have slightly higher compression figures because of that. Of a healthy engine you should be looking for 160-170psi. As long as they are all within 10-12psi it should be fine but with 90 psi you will be down a fair bit on power.
EDIT!!
Here's the figures from my manuals;
1.20 MPa = 12 BAR = 176.4 psi
1BAR = 14.7 psi
Standard: 176.4 psi
Limit : 132.3 psi
Difference between cylinders: 14.7 psi
Edited by D_Stirls
EDIT!!
<snip>
1BAR = 14.7 psi
Standard: 176.4 psi
Limit : 132.3 psi
Ive got between 80 - 92 psi on all 6 lol
need some advise,
the fan that sits onfront of the rad has the mesh around it..
does that need to be connected? mine is running consistanly and is pissing me off..
can i disconnect it?
thats the aircon fan mate, confirming you're talkin about the one thats in front (and by front we'd mean closest to the front of the car) of the radiator?
if so, definitely a/c fan, and its probably still sitting in front of the aircon radiator anyways (have you gone that extensive when the actual radiator was out, and get the other radiator (which tucks in under the rad support panel) out?
i still have all the air con connected.. but i NEVER turn it on...
just in the last week the fan has been on everytime i start the car..
wont turn off so i was wondering if i can unplug it?
Guest
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
