semi right Ben
If someone is standing over your bed at 3am and you put him out of his misery, you'd spend a couple of years in court and most likely get off in the end.
Different story if someone is in your shed or backyard though, then it's a case of the "equal or lesser force" rule applicable
Aye I know this, but if someones in my yard and they DONT run then the law be damned. Like you said a few weeks ago, nobody goes to jail in this state. Public opinion on this sort of matter is enough to sway any jury.
-D
  • Replies 14.2k
Yeah i always thought they were plastic till JIS told me they were fiberglass then i looked on the auctions and found they were correct
http://page2.auctions.yahoo.co.jp/jp/auction/b107935204
Only the lips are plastic im sure.
lol good luck with that whole not going to jail reasonable force argument Ben
i almost guarantee if you shiv someone who is stealing your car that wouldn't count as reasonable force hence you loose and we visit you in the big house
and if it really was a "shiv" that would show prior intent to do somebody harm and you may end up on murder but probably dropped to manslaughter with a good QC
we'd have to get permission from his new girlfriend first........Bubba!! ;)
Guest
    • Well, the NC is just an RX8 anyway, right?
    • Now Mark, I know you've already done an engine swap, but how about doing an engine swap that reduces a lot of weight, and effectively makes it a mid mount engine setup?   https://youtu.be/A99702U07QI?feature=shared
    • Does anybody know the weight of the flywheel for the Nismo twinplate coppermix clutch kit for bnr34 over the standard flywheel? Is it a dualmass flywheel like oem or single mass?
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
