nah no shopping list
was thinking either tribal again or the swirls that the 31 has :)
and steve as if u forgot the bacon!!!!!!!!!!!!!!!!!!!!!!!!
that car paint sceme has been used a few times already,a guy in QLD on here has one on his GTT and Phatt Audio Customs in Vic has one similar turned into a JDM Cop Car.
JDM R34 cop car video
try some new graphics Cara, not the swirls or tribal ones , something fresh!! and PM or SMS me sometime homie...lol
  • Replies 14.2k
Just got a couple of quotes back for a standard rb26 bottom end swap.. 7-9k ouch.. :ninja:
Looking at a couple of built long motors in japan the moment.. One's a tomei 2.8, 270 tomei cams, tomei oil pump, N1 water pump etc. in a N1 block. Motor has just under 4000k's on it.. May aswell get it checked out by a shop over there and do it right the first time i spose..
Can't justify spending that kind of money on a standard bottom end..
sucks. :laugh:
rb30? :ninja:
I've considered this.. But weezy gets mad and reckons it's molesting it.. Might throw in a rb30et with a A6 bottom end just to make him rage.. haha
Fitspatrick had a rb26 awd adapter for $450 (don't know if they still do) then there's around $600 in machine work to relocate the oil pick up then drill and re tap the rb30 for bigger head studs and a tensioner..
Thats about as much as i've looked into it so far.
Dayum thats quite cheap...
Bargain if you can get it, tho I hate to think what the shipping fees are for something so heavy
-D
Yeah it's cheap at the moment and shipping is around the $1500 mark from what i saw. I'm keen if it goes for under 9k..
That would be around 11k all up including shipping and taxes.
If it goes for any more it might be a better option to get a nitto 2.7 built here..
Weezy has a point (as a purist lol) as Rb30 bottom ends are awesome for the power gain, but the car loses value when you take the original rb26 out of it, which is the only reason I'm going to stick with the 26 bottom end
-D
No pos RB30 bottom ends should be in a GT-R imo
:ninja:
Dont get me wrong, I'm all for twin cam RB30's in VLT's, GTSTs, etc but not a GT-R... C'mon lol
Think I should of called before I went for a drive, went all the way to MC Doyles Crash Repairs and they were closed... as in like they didnt pay their bills and got shut down. Guess I'll have to take my business elsewhere...
11k shipped for engine worth 5800?
Who's making a couple of grand?
My r34 rb26 motor was under 3k del
Yeah bit too much for shipping. I paid 60,000yen for a pallet (~A$700). If I had more money I would have loaded it up.
And Vu plz don't go to mc doyle unless u don't care about how your car comes out.
They're that bad are they? I've heard good and bad about them, was thinking I'd try them out myself but seeing they're close, ah wells.
What i was meaning to say was i'm prepared to pay 9k maximum for it and that would be around the 11k mark delivered after shipping and taxes.. If it goes for any more than that price i'd be looking into getting a motor built here.
Guest
    • Well, the NC is just an RX8 anyway, right?
    • Now Mark, I know you've already done an engine swap, but how about doing an engine swap that reduces a lot of weight, and effectively makes it a mid mount engine setup?   https://youtu.be/A99702U07QI?feature=shared
    • Does anybody know the weight of the flywheel for the Nismo twinplate coppermix clutch kit for bnr34 over the standard flywheel? Is it a dualmass flywheel like oem or single mass?
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
