Okay I pulled the hose off with the yellow stripe and I can't feel anything in the hose when I squeeze it. That would tell me that the thing isn't there. But when boosting my standard gauge only goes to the 2nd to last bar on the gauge..
What do we think is going on?
The hose feels pretty stiff as it is, though.
Mines still got the restrictor in it but I pulled out the hose and put a light into it to see the restrictor.
I'm scared if I take it out, bang goes the turbo's lol.
I can't remember what the bars on the gauge actually stand for... like isn't the 2nd bar like 10psi or something?
  • Replies 14.2k
I think the second bar up the top of the gauge is close to 14psi/1bar. Would be great if someone could actually confirm this though. f**ks me what them standard measurements are in
Which hose is the restrictor in? The bottom or the top?
this picture seems to be pointing to the bottom one which is the thicker of the two. But the top one on my car is thinner and has the yellow stripe that everyone says the restrictor is in.
I'm confused. But if its not there and I'm not running 1Bar on my standard guage.. it opens up a whole list of problems I could have..
measurements are in mmHG which is the pressure of mercury - roughly said its the amount of fluid pressure exerted by one mm of mercury, so 760mm of mercury is equal to the sea level atmospheric pressure (1 bar)
http://en.wikipedia.org/wiki/Torr
Scientific measurement, NFI why they put it in a skyline, either bar or psi would have been much better
-D
can i ring aus post to see if its here??
i know it was sent, i just want it my the weekend!!
you'll need a tracking number, like steve said if u got e-parcel u can check it on the web
otherwise give the adelaide cbd post office branch a call, they can possibly tell you if theyve a) recieved it or b) sent it off to a regional office
-D
Guest
