  • Replies 14.2k
guess I wouldn't of learnt if I didn't ask. Might see how it hooks up tomorrow morning.
this is the manual for my ebc
http://www.users.on.net/~geekhabitat/profec-B.pdf
check it out -shows u the diff turbo systems - ebc has dip switches to make it behave differently
-D
will a intake manifold of a r33 gtst fit onto ,my rb25de
the r33 one will bolt up but the ports won't match up as the NEO DE heads have different sized ports which are tiny compared to the DET ports.
Edited by D_Stirls
all the more reason to just get a complete DET, huh? :)
-D
This is what I was talking about on FB the otherday with Craig
http://www.ecutalk.com/consultlcd.aspx
NEED HELP
Lost keys to a 4wd. Don't know where they are at all. Think they might have been thrown out with the trash which was already picked up haha.
Only problem, it's a Russian built Lada Niva 4wd lol
thought about ripping the lock out of the door but a moblie lock smith didn't have a blank key to match it? And another wanted 300 bucks :s
can't be f**ked replacing the barrels and ignition with a new set from Russia but it's looking more likely by the minute.
Anyone know if there's a place that can help with weird cars like this?
NEED HELP
Dude, it's Russian, just do what the locals do - use a screwdriver!
Guest
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
