excellent.
ordered brake pads on monday, and was assured theyd be here by today.
guess what?
theyre not here.
and i have a motorkhana and a hill climb coming up.
im somewhat f**ked off. means i gotta spend another couple hundred bucks on brake pads.
money i shouldnt have to spend.
f**kin excellent.
nothing unusual, typical postage service reliability. Or maybe a poor excuse of a vendor.
Arent you selling your car though? Hillclimbs and motorkhana's are the last thing id be doing
  • Replies 14.2k
pretty well.
and yes, i am. but a) ive spent all the money getting it to a point where its a reliable go fast car, and b) the motorkhana and hill climb make up 2 of 3 days ill legally be able to drive my since january and until... november. i think.
and if i still had my licence, id still be enjoying my weekly hills runs. which is probably harder on my car.
Edited by scandyflick
honestly i would say poor vendor, i bought some parts from PC case gear money cleared 21st had parts on 22nd with e-parcel that's a guaranteed up to 10 business days
who said it was to do a DET :)
the DET gods say ;)
I agree with steve. When I ordered lukes 1600cc injectors from florida, they arrived within 5 working days and that was non priority airmail from the USA... no way they can blame the posties unless they got the most basic postal option available - and even then maybe not...
-D
i so had a little lol to my self
Guess
G Shine Clutch Bag
OTFFWN9SL_large.jpg<<click
description should say
'when your the last man on your team holding this bag provides you with clutch leetness'
'take it to your next lan and be the envy of all other players'
'in 2 fashionable colours for men and women'
:blink:
Does anyone no where i can order the part labeled 14875PA
Mine is leaking pretty bad as you can see in the photo.
Cheers
Main North Nissan should be able to get it in, usually theyre not cheap tho
Try koji at jap import spares, he can get pretty much everything nissan can but a tad cheaper (sometimes)
he might have a second hand unit tho... ditto for nisswreck and JMS, they're all worth calling/emailing
-D
-D
you wouldnt happen to no what its called would you?
Guest
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
