Just got back from Melbourne. Left Adelaide at 4:10Pm yesturday arrived in melb at 5:30ish melb time. Picked up a 280rwkw supra with a mate and drove it back.
First road trip. Wasn't to bad :happy:
I like the trip between Adelaide/Melbourne - its not too long.
It was epicly fun driving back in the GTR... and kind of not at the same time(stiff suspension and loud exhaust with windows down made the right ear feel a bit funny after awhile), and surprising not too bad on the wallet - less than 2 tanks of fuel.
  • Replies 14.2k
i did adelaide to canbera in a stiff as coilover swift with no a/c in 40 degree heat. we were both burnt like lobsters on arrival. went through about 10 litres of water each.
but you gota look at it as an advernture :happy: and country people are funny when they see a modded car
Edited by Inline 6
On the weekend I drove to and from bendigo, VIC in an R33 with coilovers and 300~rwkw and only wet through roughly 4 tanks of fuel including driving around bendigo and heathcote,
I wasn't a problem at all.
SOO my horns dont work now
press the horn button and all i get is clicking in the engine bay from the relay
ive replaced all the fuses to no success
so this would indicate that the horn has been shorted out
correct me!
Guest
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
