If you want to bring it up to my place on Wednesday night i'll do it for you, and i have the right tools LOL.
If you don't have the right shape drifts you will find it very had to get the bearing keepers back in.
Keen to take you up on this also Dale, will PM ya when I acquire funds lol.
  • Replies 14.2k
Anyone know any good gym equipment whole salers in Adelaide that do decent prices on things like bench, bench bar, adj dumbells, etc etc.
Not interested in a cable system as I prefure free weights, loss of license means no way to get to a gym so I'll bring a gym home LOL
There's some mob on Port Road, Hindmarsh who I can't recall their name. They have decent equipment. Just up from the Entertainment Centre if you're willing to suss it out.
I don't get out to a gym much anymore, so I have my own home gym that gets used more than any gym franchise I once joined. I don't have the full range of equipment like a proper gym ... but at least I don't have to wait to use my home equipment.
What headgasket should i run on my rb25det? Was quoting a rough estimate on a ACL Metal Head Gasket from turbo tune fr about 250 300, i think it was and also is it worth geting the ARP head bolts?
depends on the application? Making enough power to warrant a steel head hasket and stronger bolts?
Just do it, for a few dollars now, you won't regret it later. I'm doing mine soon, including a port/polish on the head and I'll be going the same route (Metal HG and ARP head studs)
yeah i have to have my head inspected for cracks and shit, so also thinking a port and polish.
Its actually in a VL for now haha
<br />There's some mob on Port Road, Hindmarsh who I can't recall their name. They have decent equipment. Just up from the Entertainment Centre if you're willing to suss it out. <br /><br />I don't get out to a gym much anymore, so I have my own home gym that gets used more than any gym franchise I once joined. I don't have the full range of equipment like a proper gym ... but at least I don't have to wait to use my home equipment. <br /><br /><img src="http://www.skylinesaustralia.com/forums/style_emoticons/default/thumbsup.gif" style="vertical-align:middle" emoid=":)" border="0" alt="thumbsup.gif" /><br />
<br /><br /><br />
Cheers Rubz, I'll go for a drive tonight and see if I can see what your talking about.
I'm down with you on that I HATE waiting for equipment at the gym. I'm really keen on a bench and free weights, adjustable dumbell and bench bar and you can basically work out every part of your body from that and the fact its free weight the surrounding muscles get a workout to stabalize the weights. Cable sh!t doesn't do it for me.
Don't forget guys that if you if you are going to run metal head gaskets you will need to prep both the head and block mating surfaces to the correct finish. If you don't then there is a fair chance that they will leak.
Now you have to ask yourself how you are going to prep the block with the pistons in place.
Also don't forget that if you are going to change to ARP studs then you will need to torque plate hone the bores as you will be using greater torque settings and the bore will be more deformed. This is the same story for main studs in that you will need to line bore the mains.
So i guess the moral of the story is that if you are going to do a rebuild it a perfect opportunity to change to MLS head gasket and ARP studs, but other than with a rebuild it's not the ideal time to change.
There are many flaws in that argument Steve, but surely even you recognise that 'God' is a word that men created to describe events that they couldn't understand. For the above statement to hold true God would have to be measurable like light and heat.
Also you can watch evolution at work by studying a virus (although there is some debate as to whether viruses can be considered a form of life or something that exists at the edge of life).
Last time I checked Dave, it was the other way around.
I prefer to believe that I was created in the image of God rather than have evolved from a Baboon....although when I wake up some mornings, the mirror tells me a different story :)
Weezy, the place that Roo is referring to doesn't make good quality commercial stuff....unless times have changed.
I had some commercial grade equipment made up many many years ago at a place further west of the that place (SA Gym Equipment 456 Port Road, Hindmarsh).
I'm not sure if they are still there (probably not) but unlike most places, this mob used cast pulleys (not plastic) with bearings (not nylon bushes) and heavier grade cable. They had a wide range of olympic bars & benches, power racks and smith machines with ball brgs rather than nylon bushes.
They'd custom make anything you wanted.
You're welcome to check out my set up if you ever need to get ideas.
Spot on Dale, unlike a composition style head gasket, metal shims are nowhere near as forgiving.
As for torque plates, I've measued bores on some overbored blocks from underneath with an internal micrometer after a head was bolted on to find an oval bore with a discrepancy of as much as .010" (.025mm).....and peeps wonder why some recon engines burn more oil than worn out ones, lol.
Line boring mains isn't always necessary though, but you should still torque the main caps with brgs installed (but crank removed) and check for clearance, end float and brg crush before final assembly.
My only problem is my pocket isn't oozing with disposiable money - I'm sure getting something custom made etc would cost a pretty penny,
Having said that I know this stuff is expensive but you can go over board, so I don't mind forking out coin to a degree lol
PM me some photos of your setup if you don't mind Pete? I'll have to swing passed there and have a look.
Edited by Weezy
I've only got one a bit weeks left of license left rofl,
So you think SA Gym Equipment are the way to go? or are they the ones that build poor quality?
SA Gym Equipment are the good guys....that's where I got my gear from.
But like I said, I don't think they're there anymore......not sure if they've closed for good or just moved......check the above address first.
Guest
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
