  • Replies 14.2k
anyone know about the R32 steering wheel and how many things you need to remove to be able to take it off. I just need to simply move it over to the left a few notches grrr.
stock wheel or aftermarket?
gotta take the horn off and then use a certain type of hex nut to remove the retainer bolt - not sure what tool or what size it is to remove it (im no mechanic) but its not too hard. assuming your wheel isnt quite lined up to spline 0 and ur hicas is wigging out?
-D
will r33 radiator fit directly into r32? and is it upgrade?
if you're looking for a good upgrade, the isc 52mm is the biggest u can fit in the 32 without modifying the fan and shroud
I love mine ;D
it keeps me warm at night
-D
sorry man would be down but i picked up a ankle injury during my last game. Dr says ive damaged ligaments :D
but i got a rebound and scored when it happened so that makes it worthwhile right?
apparently the treatment is R.I.C.E. so ive installed neons on my foot and trying to incorporate crome
Edited by Inline 6
how your ankles? im a bit worried it might not be the same again for a long whiles.
sh*ts got me feeling old, felt like wolverine as a kid. sh*t would just heal in a day. now i gota worry about breaking my hip every game.
Edited by Inline 6
welcome to my world, bitch.
-D
Shiny new Wasteland, I see... :D
I've got a chip in my windscreen and I want to get it fixed. I've called O'Brien up and they said they'll repair it (probably with that glue-type stuff) for $116. Anyone know of any other place that might do it cheaper? The car's going on sale soon so I need to get it done ASAP.
Guest
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
