  • Replies 14.2k
even the biggest computer retard can see the little box next to safari and bonjour, and then click them off so that the only update they receive is for itunes. and if you fail to do that, even my alzheimers suffering 80 year old grandmother knows how to remove software.
haha cops arse Dave!!! You'll be surprised... people just hit the update button. Seen it many times on friends and family members PC's and ask 'why the f did you install safari'... to a reply of 'what's safari?'
On one occasion with my old pc - I left it running for a couple of days straight while ripping down a big torrent. Came home from work and found bounjour and safari both installed... now unless my cat decided to jump on and have a game of solitare, how the f**k did that manage to install!
edit - bloody swearing filter
Hey Dohmar, could you price me up some 500cc or similar injectors for RB20, Ceffy needs more powwar!
approx $550 (aud) delivered for a set of 6 550cc lucas injectors for rb20 (high impedance) - could be cheaper if our dollar goes up, cheaper still if you have a low impedance injector conversion (rb26 injectors cheaper than rb20 for some reason)
-D
nice 1 Josh
Mitch - expect to pay $550 + 30 shipping for the NPC 5puk cushioned button clutch its rated to 350rwkw or about 330awkw and 1200kg pressure plate
I'm organising a couple soon so if in 4 weeks all you guys are ready to order would make NPC's day :/
this is how he makes the clutch
>>original group buy #2<<
PM me a few days before it happens and ill let you know :P
ahk , im gonna need a new clutch soon i think
mines got stuff all meat left
but i dont know what to get lol
I am running a F1 racing stage 4 clutch....bought it off habibay and its looking pretty good atm.....holds 250rwkw and has had a full track day flogging.....plus the usual flogging from when it gets driven.....nice and soft pedal.....way better then my excedy clutch that i had in there before.....bare in mind that clutch was rooted lol.....and that came with thrust bearing and pressure plate for $350 del
Woke up to a $2543 phone bill from 3.
Rang them up, and luckily... They admitted they f**ked up. Now it's only $119.
That really got my heart racing for the morning!! f**k.
your partying days were almost over aye :(
Yeah maybe... Tonight I have a birthday at the stupid Highway Inn or whatever it's called, then tomorrow I have a birthday lunch, but I'll see how that one pans out!
EC's tonight or ban :(
the closest I've driven with the exedy pressure plate is Marks GTR and that was very nice to drive some might say too stiff but i like a heavy pedal
as this uses the same pressure plate I'm sure it will feel the same
i have bought braided lines and the nismo big resi as well that will soften the pedal but hopefully not too much
mine?! yeah u get used to it... its only done about 7000 kms and i love it.. recon it will only last another 7000 max with 400 kw and a soft foot though.
whats the eta on ur beast steve?!!? cant wait to have a bit of a cruizy with ya.. although im sure u'll be in ma passenger seat before too long. also just putting it out there... another geeky night at arena's? been ages and i really enjoyed it :cool: recon that was the night i was a passenger in the lovely 4 door :(
There's no reason why there can't be a day for both. 2 groups 1 sliding, 1 grip.
now this i like.. would make for a really fun day lots and lots of epic :cool:
should have more fotos and possibly a vid of engine running tonight :)
Guest
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
