Yeah and it ended up in the creek :devil: .... saw it down at Mantas last week.
I hope this vehicle description is not right - if it is an original (and worth mega $$$) why would you rally it? :P
http://www.targa.org.au/Competitors/profil...0Early%20Modern
  • Replies 14.2k
Negative on the Power FC, Andrew.
I don't understand.
Im fairly sure my #6 coilpacks is stuffed, hence why im changing coilpacks. Once the engine gets warm..after 10 minutes, it breaks into 5 cylinders, and make's WRX owners envious of my engine.
However, tonight, i did not have an issue at all..drove for about 40 minutes, except for this problem of it limiting itself to 4500rpm.
I'm going to have to assume it has something to do with the coilpacks, as the problem has just 'magically' disappeared, but this new problem has come about.
AFM wouldnt be knackered, it would be obvious there was earlier im the rev range i would think?
i dunno what coilpacks u need but i got around 6 here that are 2nd hand for the rb26 - i know a couple are buggered but u should be able to use one of them if theyre compatible with ur engine/ecu setup
-D
-D
If the redtop RB20 uses the same coilpacks as the silvertop RB20 it should be fine.
Was originally going to go with Yellow Jacket coilpacks, from their website $350 for all 6, a pretty nice price, whilst Splitfire were after $700.
Ended up talking to Decs at Garage 7 on Monday night about the problem im having, so he's going to whip up an "AU Folcon Coilpack Conversion' setup, so basically the 'hub' for my coilpack leads will instead of being on the Valley Cover, will be on the firewall.
He's done it for a few of his customers, and all have reported no problems.
Plus, even though i don't want to cheapen out on stuff with this car..i can get it cheaper then $350, plus i like supporting small business.
Thanks for your offers guys, hopefully i get it running properly by mid next week, then on to the tune, hoping like crazy for at least 180kw. Cmon redtop!
To me that's over-complicating a simple solution to a simple problem. I know others will disagree but if it were me I'd just get the Yellow Jackets, straight bolt in, no fuss, no extra looms going anywhere and doesn't look sus. Neat and simple
+1 neat and simple is what you want
I know what you are saying there Heslo and Jenkies, why complicate one small thing.
Kinda having that debate with myself at the moment.
Still undecided, and i havn't actually said "yep, lets do it". So im just mulling it over.
Car won't make any power levels needed to max out the coilpacks from Yellow Jacket anyway... hmm.
lol was mucking around.... but we do live in adelaide :ermm:
on a completely other random note.. after unloading a 40 foot container of water features and unpacking, all day, 9 hours.. i can safely say if i dont get my baby back by friday im gonna convert to the crazy side..
Guest
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
    • True! I think I'm closer to 06 with the cameras in phones being out there more. And the nearly impossible to use internet web browsers. Or paying for ring tones... Man I hated when we couldn't just compose a ringtone on a Nokia anymore! These days I just hate it if my phone rings, beeps, boops, or vibrates!
