  • Replies 14.2k
Cst's Wayne. I can hook u up a set when I'm bak in adelaide. Currently in a club in Sydney :mad:
We'll talk when your back in Adelaide man :P
Go hard! lol
Edited by Weezy
also have the thought that it was done when engine was cold so pistons and stuff still needed to expand etc..
specs:
Fully balanced
Arp main studs
Arp head studs
Acl bearings
Acl 1.2mm head gasket
Ross/acl pistons
Argo rods
Adj cam gears
Gates timing belt
Has a rb20 exhaust cam on the intake to take the vct off
Was built with all new Nissan bolts, gaskets, seals
Once you have different cams and or adjustable gears, comparing compression results to factory will tell you nothing. This is also the same if you fit a different H/Gasket and the pistons will probably be slightly different compression to the factory ones as well. The difference between the cylinders is what you have to look at but a leak down test is what you really need.
You wouldn't want the difference between cylinders to be more than 10 psi but that's probably not to bad for a cold test.
Edited by D_Stirls
yeh i was reading and found the results not to be too bad..
going to go look at the motor and possibly purchase it.. fit my cams, plenum, turbo etc...
and dale i love my eboost...
would never let it go!
Funny:
Bloody lucky:
:blink:
Brass balls for the bloke. I was at eagle on the hill one day back in 2009 and there was a bunch of hecktik biker boys in full leather on their GSXR's etc racing up and down, in 45 degree heat :\ Crazy kents!
I found out what that grinding noise was, in my drivers side wheel arch. The retaining pin for the hand brake shoe had popped off, and got stuck in the drum, where it started to get ground down. Now to source a pin, and spring.
EDIT: about $5 for a pin and spring from Grand Nissan, so I have ordered 4, may as well replace them all while I am at it, should be here tomorrow or the day after from Melbourne.
Guest
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
