  • Replies 14.2k
i knnow fitting restictors and doing internal mods but shaun said not to worry unless your rebuilding..
i have mines cam baffles and 26 covers which will help..
all built engines i have read in the FI have had this mod done!
What are you doing it for? I have a 26 which are bad for oil problems and i wouldn't even bother with one.
coz mines gonna see some limiter loving come june 19th drift prac!
and im just making a $200 sacrifice to save my engine..
i did read that unless u have a aftermarket oil pump u dont really need to do the external oil drain..
the baffles should be fine with a catch can setup..
Just fill the oil up to the top of the H on the dipstick, That's how i keep my RB's alive on the track.
and its worked so far
from what i saw it wasn't easy track time either and what maybe 8 laps with some drifting on the SAU|sa track day
In other news, "Lost" sucks a fat dick and I'm glad it's over, that ending was... was... there are no words
OOOooooh don't spoil it - I'm just about to finally get around to watching it (just watched the 1 hour 6 season-spanning re-cap episode) ..
Gah! Now I'm stressing that I've wasted the time watching 6 seasons of a tv show :cheers:
I personally thought it was a piece of shit but you're experience may be different. Let me just say this, a certain main plot point in season 6 was TOTALLY useless, the last few minutes of the show totally wipe it out. That and the "ending" was something the creators said from day one would never be the ending
Guest
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
