Grrrr what is it with people on the forums selling stuff with comments like 'its the complete kit' and 'everything is there' ... you shell out your hard-earned, it arrives - and find out it isn't all there ....
... and when you explain how it isn't there, show pics of what you recieved, against what you should have they say 'well I got it off a mate - I never used it - he said it was all there - I can't offer you a refund'.
Uhhh wut? How is his not knowing what he has suddenly my problem? He represented a product as something it wasn't which is a clear breach of the Fair Trading act. I really hope I don't have to take this to small claims to get my money back. The item clearly wasn't as described, so I've easily got a case, but ugh - so much trouble - especially interstate.
What a frustrating and expensive experience :rofl:
<end rant>
  • Replies 14.2k
i am looking at getting an oil pressure gauge fitted to my car.....now i do know that you need an oil filter sandwich plate....but do i need one if i have an oil cooler kit with the filter relocator? as from what i can see the sandwich plate is already there??? can someone please help :rofl:
Nope, you should be fine. There should be a grub screw on the relocator that you can tap into for the sender unit
Does using a lawyer to dispute a fine to keep your license count?
Because I used Michael Woods lawyers. They specialize in traffic law/getting your license back. Pricey, but they got me through.
I'll give them a call,
Can you PM me with what you went through and rough price on what the whole thing ended up costing you?
i got nfi what I'm up for LOL. 2 weeks into no license, 50 weeks to go - its doing my head in!
what a jip.
bought $1800 worth (incl. shipping fee) of goods, sent on pallet via boat from a japanese port to adelaide
had to pay all up an extra $1100 to get the goods released.
what a jip. so many fees and charges to receive a shipment Id paid for.
on that note - DO NOT buy a roll cage overseas.
unless they cut the main bar, you need to ship it.
but because I had the cage, i added mags, cams, more parts
to make it worth my while. but fees from the docks is outrageous. they hold you to ransom.
if in didnt pay the release fee they'd hold the goods (storage fees) then dispose of and still bill me.
what a jip.
should have split it up into 2 packages. dont need to pay import tax if the package is worth under $1k
-D
lol pwnt, and you were bragging on your epic bargains.
doh
1st time Ive been f**ked over by one of 'em
and yesterday doing up my epic bargain wilwood racing brake set I snapped the bleed screw assembly by overtightening the speed bleeder
grr
i am looking at getting an oil pressure gauge fitted to my car.....now i do know that you need an oil filter sandwich plate....but do i need one if i have an oil cooler kit with the filter relocator? as from what i can see the sandwich plate is already there??? can someone please help :rofl2:
Is your sandwich plate billet or cast? you need the thick billet ones to fit a pressure sender unit.
Surely he could tap into any oil line with a t piece and then run a gauge off that? Pascals law says "pressure exerted anywhere in a confined fluid is transmitted equally in all directions throughout the fluid."
-D
Guest
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
