  • Replies 14.2k
anyone know if i can get a day pass on my car so i can drive it to a workshop for this saturday ?
car is un-registered and plates are basically expired so i dont have the $300+ for all this
id be going to midas at pt adelaide and back on saturday
you definitely can Mitch
i think its around 30 bucks or so for one of the short term permits
http://www.sa.gov.au/upload/franchise/Tran...tration/MR2.pdf
soooo, my mate has this turbs sittin in his shed, a mate of his bought it from jaustech 8 months ago for
800 bucks,
i took it to simon at morpowa and he thinks its an old trust unit.
has t3/4 flange so will bolt up to the 20, but no water lines.. only oil.
steel wheeled, and thats bout all he could tell me, besides he prob wouldnt put it on the 20.
i can have it for 200,... not sure if i wanna risk it not being what i want, or pick up a vg30...
Couple of pics of the 26 update.
Have removed AAC valve and cleaned it all up.
Removed throttle bodies and cleaned
Removed some coolent things next to oil filter and cleaned.
Will be replacing all intake gaskets and replacing heater hoses with black silicon.
Im glad i got mine for the price i did. $1250 for all 4 245/40/18 :D
Shit head :)
Yeah that was a good deal but DAMN the tires make an assload of difference Chad. I can see how you were going like you did on the track day now
And Luke, be careful working around the throttle bodies. A lot of people clean them thinking they are doing good and end up having shitty idling problems till the end of time
Shit head :)
Anyone who says that semi's are no good on the street really have no idea what there on about. Matt (Whatsisname) has them on his car and he cant believe how good they are either.
800 bucks,
give it to me and i'll put it on my lawn mower :)
Spot on!
hmmm google says its a trust TD-06....
what should i do guys?
Listen to your tuner, that's why they get the big bucks
Has it got any numbers on the CHRA and what are the numbers on the compressor housing?
I was thinking it was a Mitsubishi turbo and if it come up as a TD06 then that would confirm it. What is the compressor inducer measurement?
Ive looked up the thread on here about the special coating thats on them. Have use throttle body cleaner on them. The coating is still on there as i can see.
Cheers for the heads up tho.
Guest
    • Vinyl paint always ends up coming off interior trim and looking like arse. For the a pillar trims.....just try cleaning them with fabric shampoo? Maybe ditto for the headliner.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
