  • Replies 14.2k
Anyone who says that semi's are no good on the street really have no idea what there on about. Matt (Whatsisname) has them on his car and he cant believe how good they are either.
I'm thinking it's time for semi's on the street, t1r's are struggling, i'm guessing the ku36's are so cheap because there shit?
Ive looked up the thread on here about the special coating thats on them. Have use throttle body cleaner on them. The coating is still on there as i can see.
Cheers for the heads up tho.
No problem, just giving you the heads up :)
number on front is 49179-53
compressor wheel inlet is 5.5 cm...
looking into it, it seems it will to laggy for drift.
Last question, How many blades on the turbine wheel and measure the exducer on that as well.
P.S. the compressor inducer wouldn't be 52.7mm not 55 would it?
well i think it's an early version (judging by the compressor wheel) of a TD06SH-20G.
It'll be laggy as it's the biggest of the TD06's before you go to a T67. But it's a 330kw turbo.
It's too big for a 20 though, See you should have gone 25. ;)
Edited by D_Stirls
so for track purposes, its not really ideal eh?
im not scared to keep the revs up, and the extra tyre smoke would be kinda cool!
how would i go getting round the coolant lines? join them together?
edit: just seen your edit. i wont bother with it.....
what to get what to get??????????
Edited by craig R33
I'm not sure about that compressor wheel, i can't find anything that even looks close to it and it doesn't look like the current generation of 20G wheels although the inducer specs are very similar to the 20G size.
I have something perfect for you; BRB.
Edited by D_Stirls
Here you go it's a perfect turbo for a 20.
http://www.nissansilvia.com/forums/index.p...howtopic=414681.
You can get 300kw our of this turbo but 260-280kw is more reasonable.
And don't fore get that this is a $1800 turbo when it is new. You might want to change the turbine housing though.
EDIT!! Sorry missed the bit that said that it was sold.....lol
Edited by D_Stirls
Guest
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
