  • Replies 14.2k
We are supposed to be there 9am SHARP to set up Steve - they will want to position and rope off the cars .... highly doubt you will have time to get the snags in the morning. Have you cut up the onions?
I'm going to to be down there some stage after 12pm if thats okay Andrew as per prev PM's?
You going to be there untill like 4pm - 5pm?
i already have the snags Andrew i just need to stop by coles get drinks and bread and onions will cut up on site :)
ill try to leave home @ 8am and get to coles and that shouldn't take too long bbq isn't starting till 10am
i will get ice from BP will Jas be on ?? :laugh: :laugh:
i will be bringing a table for bbq stuff if you want to setup merch than maybe bring your little silver table
Cheers mate and thanks for the offer :cool: I'll be sure to have you guys round for a housewarming :)
Been meaning to ask you. What stuff u use to render? Might be able to get you cheap bags of stuff to.
I only use Dulux product and AFAIK they don't outsource, only sell from their outlets. We use mass quantities so get good pricing regardless. Do you stock bag render? What brand?
Render? Jesus! :cool: That just reminds me of another job I got for the house! There are days when you'll regret home ownership dude :D
I just realised I have a problem ...
I buy bikes, and I mod them.
I buy cars, and I mod them.
I buy houses, and I mod them :)
I bought a lawnmower and couldn't help but modify that! What sicko modifies a lawnmower?!? I can't leave anything alone :)
That's the good thing about being in the construction industry, I know people so I can get stuff a lot cheaper than the average joe. Give us a holler if you want your place rendered, would come up quite nice IMO
^ probably fairly south of the border, I had 17 x 9 +20 with a 225/45 and it was nice and flush with stockish guards and 3.5 camber all round. Would prob need a bit of a massage if you want flush.
so here i am , sitting at my pc at 4am in the morning and ive started thinking about putting my dented r33 shell to good use as a drift hack...
thinking about putting my whole car into it basically...
just so that i can skid it and not have to worry about paint work getting scratched , panels getting macked in etc etc
sorta missle spec.
should i do it ? :cool:
i think im loosing my mind...
I think you should just go hard in the orange one, bugger a trackie.
Edited by AndrewJZX100
Guest
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
