  • Replies 14.2k
sorry to hear of your car Carl
i had the same thing happen to me 2 weeks ago in the camry power steering stopped and i couldn't turn, i stopped the car mid way through a corner and turned it back on all was good lucky i was in the back streets
well i just crashed the 32 a lil bit
got out the driveway, and noticed the squealing of cold belts slipping wasnt stopping, so i pulled over and had a look. what i thought was the air-con belt had jumped over one spline and was sitting on an angle. so i thought i would nurse the car around the block and pop it back in the shed....
this belt turned out to be for the power steering pump, and when it went i coasted gracefully into a stobie pole and munched my passenger wing mirror cos i could barely move the fkn steering wheel. it took me 15 min to get the car 1/2 a block then in the driveway to the the round the back. i could have crawled faster using only my tongue.
**** note to self..... remember which is power steering, and which is air-con
had the same thing happen to me mid corner out near lobethal a few weeks ago , except it was a busted line :domokun:
just lost an old reserve mate over in afghanistan
R.I.P Smithy
http://www.adelaidenow.com.au/aussie-soldi...u-1225876776920
RIP To your mate matty
They shall not grow old, as we that are left grow old:
Age shall not weary them, nor the years condemn.
At the going down of the sun and in the morning
We will remember them.
-D
R.I.P Smithy
my best friends husband was good mates with him and was in his squad as a bomb and amo tech, but clinton went to Vietnam due to personal reasons very sad day for his Family, extended family and Australia
On a different note this had me in tears
check out the badge and the number plate
http://www.carsales.com.au/all-cars/privat...id=128629C972AD
holy f**k, someone post some boobs, quick, this thread is going OT!!
:) Looks like I need to start a tax thread... j/k.
Speaking of tax, with relation to cars, our window identifier codes in one of our programs at work are shown as RBxxx, so you get RB025 for the main screen and RB026 on another one.
I HATE ITUNES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
My god why does apple have to make everything so hard? Its easy to put music on but be fcuked if you can get it back off! Another reason i'll never get an iphone
Guest
    • Well, the NC is just an RX8 anyway, right?
    • Now Mark, I know you've already done an engine swap, but how about doing an engine swap that reduces a lot of weight, and effectively makes it a mid mount engine setup?   https://youtu.be/A99702U07QI?feature=shared
    • Does anybody know the weight of the flywheel for the Nismo twinplate coppermix clutch kit for bnr34 over the standard flywheel? Is it a dualmass flywheel like oem or single mass?
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
