  • Replies 14.2k
ive got a usb cable which is that ^
does it HAVE to be firewire to work ?
Has to be Firewire, USB and Firewire are 2 separate communication types. So, yes it DOES need to be Firewire. There is a USB cable that looks similar, but will not work.
so my brand new, less then a week old lap top blue screened on me and when i got it started up again i get this:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.768.3
Locale ID: 3081
Additional information about the problem:
BCCode: 1000007e
BCP1: FFFFFFFFC0000005
BCP2: 0000000000000000
BCP3: FFFFF88002FD1B48
BCP4: FFFFF88002FD13B0
OS Version: 6_1_7600
Service Pack: 0_0
Product: 768_1
should i be worried? it hasnt happened again but i've only had this thing like 4-5 days.
ahhh ,
will have to go to dick smith tomorrow n get one
does that mean i can upload it using movie maker on my pc?
ahhh ,
Yes, I use my mum's video camera, and use windows movie maker to import and edit the footage, my dyno run that I recorded was done that way. Windows XP, Vista and 7 have it, you may have to download ot for windows 7, still free.
gonna do something about your cooling panel and hood getting all touchy feel while youve got it all off?
Yeah, I'm gonna get onto that and a few other little oddities in the next few days, not like the car is going anywhere
Guest
    • Well, the NC is just an RX8 anyway, right?
    • Now Mark, I know you've already done an engine swap, but how about doing an engine swap that reduces a lot of weight, and effectively makes it a mid mount engine setup?   https://youtu.be/A99702U07QI?feature=shared
    • Does anybody know the weight of the flywheel for the Nismo twinplate coppermix clutch kit for bnr34 over the standard flywheel? Is it a dualmass flywheel like oem or single mass?
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
