  • Replies 14.2k
I have nothing against rotary engines, in fact I love them and the sound they make, but I have to agree with the whole 3.9L displacement argument as each rotor has 3 combustible sides to it for every one rotor revolution (not crank or eccentric shaft revolution).
Yeah that's true but only one side of the rotor get's used per revolution of the output (Eccentric) shaft so there for only 1.3 litres (0.66 x 2 for a 13B) gets used per revolution. You need to forget about the revolution of the rotor becasue everything is measured (RPM and Power) on the output shaft on every engine. You never see a piston speed gauge on your dashboard do you. It's like saying that the rotation of the cam shaft is vital to the running of a 4 stroke engine so really the redline of our nissan engines is really around the 3750 rpm mark.
what is this? i know its a drive shaft.. or is it drive shaft AND tail shaft....
it come out of teh vl with 20, so is it specific to vl rb20 or will it suit 25, 30, R31's etc?
sellin it on ebay thats all :laugh:
Edited by craig R33
the output shafts for RB30e and the RB20 gearboxes are the same so it's a VL tailshaft and will suit anything with either of those GB's. I haven't mentioned the 30et's because i'm not sure if the output shafts are the same, as i'm lead to believe that they had a stronger box so they may have a different output shaft.
Edited by D_Stirls
go for it, what have you got to lose. It's much the same as just pulling the engine out and putting it back in with the nissan stuff as it's all pretty modular.
My conversion for instance;
RB25 > S13
-Use a Cheffy X member that bolts straight up to the S-Series chassis rails.
-Then use RB20 Engine mounts brackets, that bolt straight up to the 25
-Use some off the shelf rubber mounts (i have some ideas here but we'll see if they will work and or be an improvement on the RB20 mounts.
-The only bit that has to be custom made is the gearbox X-member, which is no problem for me and infact i'll be making up some CNC brackets that Matt can then sell.
-Almost forgot the custom tail shaft which will cost $250 for an engineering fabriction place that makes tails shafts.
There you go the mechanical part is done.
Edited by D_Stirls
Stolen from ns.com but lol's all around... Fast and the Furious-styles.
ive seen worse ones, that are obviously made up,
one of a skyline i think that was "going too fast for me to get the number plates" or "car was drifting behind me so i pulled over because i was scared"
so, had a couple problems with the 200 at the track day;
http://www.skylinesaustralia.com/forums/Fu...ge-t293848.html
any help would be rad.
EDIT: luke loves the buttsecks
Edited by scandyflick
pathetic
while im all for a laugh, this is about 12 months too old
-D
Guest
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
