  • Replies 14.2k
Well. My poor R32 has developed a driveline problem. It seems the clutch wont disengage the gearbox fully. I drove down half of my street in 2nd gear with foot on the clutch. It crunches 90% of gearchanges, and to put it in 1st the car needs to be switched off, select gear, then start again. When you take off it shudders and makes a clunking sound. Been talking to Dave and he has suggested checking out the clutch fork, slave, and pivot.
Have you bled clutch correctly? Do it on a hoist (like I did) so you can see the amount of fork travel at the slave cylinder. And bleed it from ALL bled valves. My Stagea has 3.
:thumbsup:
I did bleed the clutch, albeit on axle stands, and it all seemed to be doing its job. I will have a look if I get time, but Ive got an appointment, need to finish a uni assignment thats due today and work. Cheers guys.
blokes just throwing it out there small cruise happening sat night at bunnings parafield 7pm just carpark to carpark deal anyones welcome should be a majority xr6t's but we get 1 or 3 skylines rock up so if u want a fair quick paced run sat night cum down and talk shit and say hi
Alot of SA people are going to the Kadina Show and Shine this weekend, so you might not get much of a response. And maybe dont include the meet location, unless you want unwanted visitors, and i dont just mean cops! :thumbsup:
easiest way to bleed nissan clutches is to have 4 hours and plenty of beer spare, or buy a 1pc braided line from master to slave and p1ss the balance block and damper pipe off. Most good workshops will follow the factory service manual and pressure bleed it with a vacuum device :thumbsup:
I had a similar issue, didn't crunch gears but was sticky as f**k. Clutch fork had spun on the thrust bearing and the slave was pushing the fork on an angle etc etc, it was really messy. It was all replaced before any serious dramas but frusterated the f**k out of me.
Quick Q:
Whats the main differences/advantage between R32 GTST front calipers and R33 GTST front calipers?
Is it simply the 32 is just for 280mm rotors and 33 is just for 297mm rotors. Any differences in piston sizes?
so found our new puppy after looking for a good month, bullmastiff x staffy.
only thing is, its in pt lincoln god dammit.
looks like im going for a drive next weekend
Congrats! Looks like a beautiful puppy. Please make sure you train and exercise it properly and love it dearly.
hahaha mastiff's get huge staffy is a medium dog
personally i wouldn't buy cross that's when you get temperament problems
Sorry Steve but I'm going to call bullshit on that statement.
I have volunteered at the Lonsdale RSPCA in the boarding section for over 18 months now where we have a minimum of 70 dogs every day and up to 120/130 dogs per day on long weekends. After looking after, walking, playing with, feeding and grooming 1000s of dogs I can tell you that temperament problems have nothing to do with cross breeding.
Dogs are the most loving and loyal creatures (to humans) on the planet. Temperament problems that can occur will usually be due to the humans that come in contact with the dog, its surroundings and everyday life, if the dog has been attacked before, or in some cases mental illness (just like humans have).
As someone who studied genetics I can tell you that 'pure bred' dogs have suffered from generations of in-breeding, usually grandfather & granddaughter mating, and IIRC in some breeds there are less than 50 variances in their genetic code, ie they are closer to extinction than the Panda Bear. I will need to search to provide a reference for that statement though. Cross breeds vary the genetics of the dog and are therefore likely to live longer and suffer less illness. I had all this info on my old C: drive which died so I'll have to search for the books again to elaborate further.
FYI
****WANTING TO BORROW****
Pair of NON-HID R34 headlight for regency, will swap my hid's for yours standard ones and when im off defect then swap them back and sure i can find a 6pack in it for you too.
Please get to back to me asap as regency is booked for the 22nd of june and my original headlight plan fell though
-lewis
0432 581 798
Mitch there should be something under the car, basically alittle toggle thing which u need to undo.
And Lewis I got non Xenon ones here u can borrow.
Edited by Luke_ENR34
Guest
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
