  • Replies 14.2k
http://www.adelaidenow.com.au/motorcylist-...u-1225879513502
Very, very close to where I had my accident, and the cyclist was travelling in the same direction I was. Makes my stomach churn just thinking about it. RIP to the biker :)
+1
That section of road is rubbish. Had a mate go down probably that same corner too. We had to use a car to remove his bike from being wedged into the guard rail. He was busted up pretty bad, but nothing life threatening.
Does anyone know how to fit a lift kit to a hilux?
I'm sure I could do it myself, but I've never done it before and rather someone who's done it before help out :)
please help so I can fit some 35" tread!!!
suspension lift kye? if so it'll be easy as
spring and shock are normally separate, so its just a case of out with the old in with the new
Anywhere in Adelaide that will service/diagnose some Cusco coilovers that are knocking?
So far I've tried Manta but they didn't want to touch them.
Pillow ball mounts are stuffed....get rid of them.
Rubber mounts are fine for the street and occasional track work (and much quieter)....unless it's a track car, why bother with those things.
best way to remove battery corrosion?
soapy water and a rag?
baking soda and warm water in a small cup , into a paste then spread on corrosion, rinse with fresh water, but DO NOT get into open cells where you fill water
think you meant distilled water weezy ? it goes inside the battery
random car porn
i gotta do my whole boot :D
mix it in a sprayer a lot thinner it should bubble a lot then rinse with cool fresh water then dry,,,, any thick corrosion use a toothbrush or soft scrubber..
have fun...lol
PS it eats clothes slowly so do it with old crappy ones
only cost a few bucks to do it, look in the baking isle for baking soda
have fun...lol
ive got a box of baking soda in the kitchen
just trying to work out what mixture to use as the last time i did it , well failed epicly because corrosion is back again ...
Guest
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
