  • Replies 14.2k
man, just putting a wheel back on ruins me (knees)... certainly with the cold weather.
nasty stuff with no patella's
got all this stuff on the go with the r32 rb26 but cant muster the will in my knees to do anything.
so so need a car hoist, and hell a heated garage with plug-in knee warmers would be nice
do u wear pressure braces on ur knees? probably a dumb question but i use em on my wrists for RSI
sounds like u need some bionic knees dude, either that or get em chopped off and get a couple of struts bolted to ur femur and get urself a spare rim and run a single toyo r1r on it...
-D
ive got a box of baking soda in the kitchen
just trying to work out what mixture to use as the last time i did it , well failed epicly because corrosion is back again ...
Baking Soda is what pro mechanics use with warm water , no real trick to doing it , but you must prevent corrosion by taking that battery out , which by the way its illegal to use a wet cell battery in the boot of your car ADR without proper venting,drain holes. and as you can see , there a crappy battery that farks everything when it spills. buy a gel cell or AGM battery and redo the connectors , no more corrosion from acid
plus the car will thank you by starting easier
boiling water does sweet fark all , unless you want to make things steamy too..lol or if you rinse with it.
you can get a battery spray that coats the terminals with some redish oily crap to seal the corrosion off, might find it in a boat store , haven't seen it in normal car shops here in OZ
Good news Luke!
In other news, dropped my head off to Rhemac tonight, wicked set up they have going there, some serious work gets pumped out of there! Bad news is I left there with more options, and unfortunately, more money to spend. It's more of a case as to how far do you go, you need to draw the line somewhere, I just don't know where that is
Guest
