  • Replies 14.2k
hot week next week, unfortunatly my aircon compressor bearing is siezed, any ideas on cost for repairs?
My aircon compressor clutch is fecked, been like it ever since I bought it. Got quoted roughly $450 for a s/h compressor, fitting and gassing from Jaustec.
thats who i was thinking of going through, how long ago was that quote done?
think i might go without it for a while longer then, haha.
ITS ALIVE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Finally good to see Mitch...i am guessing that you haven't hooked up the stock boost gauge line either?? and as far as i know there should be a connection for the oil pressure....ahh well just get aftermarket gauge that will prob be more accurate
took my R31 to a place in lonsdale on o sulleys rd near the old ASV building who fixed the leak , new condenser and swapped out the compressor for about 300 all up including regas,top work for cheapest I could find around the south.
gotta love the ole UFC Damo......NOT for the faint hearted though (I know Carl - Bezender would agree with me)
I'd love to go toe to toe with a couple of the serial pests on these boards....may even teach them a little respect for the old fellas, lol :)
Guest
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
