f**k the spectators !
when your on the track you forget about em anyways
first time i was out i was like ''OMG OMG OMG OMG OMG'' then after a couple laps i was chilled
crankin some beats while your in line waiting to have a run chills ya out
after a couple of times going around and just doing some clutch kicks i was entering corners on the handbrake ;)
you think its gonna be nerve racking but its not after a few laps :P
  • Replies 14.2k
I'm not too sure yet man. I've got my eye on a few cars but ideally it'll be something 'S' chassis so S13 or 180sx mainly because their is epic amount of parts available for these, cheap, and I love the styling of them. Smashed up pig S13/180 is hot lol aswell as a clean streeter with outrageous fitment.
Did it take you a couple of laps to get into the swing of things, like basically not sliding the first few laps?
Be good for the first timers if they let us just lap the track a couple times just to get the feel of the track
yeah man, just drive a lap normally, then just clutch kick OUT of corners to get a feel of things
anf before you know it, you will feel at home
next prac will be my first with a handbreak, so will be new beginnings for me aswell
yeah man , just took it easy and got a feel for the track
if theres one thing i learnt , its that mallala is slippery enough in the dry , let alone the wet !
i wanna head out saturday but cant afford to , ill be at the next prac fo sho if i still have my car !
Wayne try and get into a drift school when they have them.
I'll be buying a slider next year I reckon hehe
Yeah man, I do intend on attending one of them courses but the next one isn't untill October and I want to start sliding before then lol
I'll probably be out at the skid prac in August
If there is a private grip day before then I'll even go to that, i don't care what I do, I'm racing haha.
I'll even drag race the cvnt if we had a track in Adelaide :P
grip days are before drift prac
ie in the morning ;)
Don't they hold alot of motorcycle events during the day? I'm more interested in a private day. When is SAU:SA holding another event?1?!?!?!?!??!?111oneeeneeeeOMFG!!ZOR1!!!1
every now n then
im also keen for a private grip day!
every now n then
Keep ya skirts on people ... an announcement will be made soon on the next track day when we can work out a date that doesn't clash with other events (by either SAU-SA or another party). :P
quick !
before my Nissan disappears !
they dont have to go hammer and tongs, and adrift day is limited to 10 spots
surely theres ten people with some sort of testicles in there pants
Just bear with me for a bit. I'm sussing out another option. Holding a drift day for 10 entrants gets heavy on the cash for the entrants. I may have a cheaper option in mind. Need to discuss with the Committee first.
:P
Had I a car to drift with, I would be out there. Give me yours and I'm down like a clown :P
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
