  • Replies 14.2k
ok boys i need some help.
My drain has been blocked for about a week now (I think its blocked) when you have a shower the water comes up out of the drain on the floor which is under the bench told agent at the inspection last week and the landlord sent his mum here about 15 min ago with some stuff in a black bottle saying sulfuric acid for drains, I read the instructions and poured 1/4 of the bottle down the drain and stand for 5 min then flush with cold water but it started smoking and had this really bad smell, i put a folded up towel over my face and held my breath and put the bath tap on and the smell has gone through my house and i have thrown up everywhere out the front. WTF
http://www.adelaidenow.com.au/news/south-a...3-1225882947361
NS.com does something good for a change... and gets in the paper.
Good on 'em :D
Thank f**k... Amber Petty has gone from SAFM.
Hopefully she's also left Adelaide for good.
+1
(waits for Melissa to flame me) :)
LOL Kelly.......tell him you want a plumber NOW!!
Depends on if your plumbing is PVC or earthenware, in most older areas it will be earthenware in the ground and PVC or Galv under the house depending on age. The smell might very well have been the Sulphuric acid eating through the PVC, normally Drano will smell a little (mainly like Amonia) but shouldn't be that bad and really shouldn't travel through the whole house.
She looks like a boiled horse! :D
hahaha that was pretty funny
regardless of what we do.....all it takes is another peanut to do something stupid in a import and we are back to square one
tell your landlord that you want a plumber asap.....not his f**king mum......most cases the landlords cover the bill sent by the plumber etc.......sulfuric acid is highly toxic kelly......if you have been throwing up everywhere then my suggestion is go and see a doc asap......also have to make sure that there is no toxic "air" in the house as it will affect everyone in the house.....if you cant smell it doesnt mean it isnt there.....be safe
I sent him a SMS and he hasnt replied just like it took 12 months to fix the roof in the laundry cause if it was raining outside sure as shit it would be raining inside
+1 Pete, what a shit landlord! God forbid the roof caves in, he will give you a hammer, some nails, and tell you to fix it!
most probably would, the heater blew up last week up and he told me if insurance doesnt cover it i will have to go with out for a month or 2 until he can afford to buy one
It was so bad i couldnt go in the house for over an hour also the house is about 40yrs old
also depends what was clogging up the drain :|
I dont know, i dont have long hair
and Krish i know i rang the poisions info line cause i rang my step dad and he went nuts at me cause he should have come and done it and im also almost 4 months pregnant they said i should be fine but yeah, the stuff is called mo-flo
Hey Kel, have a read through ur rental agreement. Are there any clauses relating to repair? i used to property manage a block of flats, and for items that are considered a necessity of daily life i wrote in there would be a 2-4 hour response time to assess any damage/need for repair.
it did result in me getting up in the wee hours a few times and repairing fuses, and also sussing out busted water heaters. From there i would make a verbal commitment to the tennant with a maximum time that it would take to resolve (i used to go out on a limb big time with this).
It is fairly common for land lords to want to fix things themselves... but that being said, i find it hard to believe the "mum" didnt stick around to make sure it works ok now. im my opinion both yourself and the landlord have taken reasonable action so far (apart from the mums lack of giving a shit). Given that working drains are a necessity of daily life, a plumber should be sent out quick smart.... not only so you dont have to be in a stinky flooded shower, but it also could cause further damage to the property (i'd play this card with the land son of rajab.... it is their investment after all)
/2c
Postie just rocked up with my new toy (the one on the left is new - I already had the V35). Stoked for just over $50 delivered for a 1:24 Jada diecast. Pics don't do it justice! The smaller one is my R35GTR Transformer :P
Guest
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
